Введение
This guide will show you how to properly install a new blade to your Ryobi CSB125 circular saw. When performing cuts, if there is a burning smell then most likely the blade is either dirty or dull. In this case, the blade should be replaced with a new one. This troubleshooting page will help diagnose any potential problems occurring due to a faulty blade. In the event that a new blade is needed, this guide will show the steps to properly install a new one. The only tool you will need is a 7”/32 allen key.
Выберете то, что вам нужно
Remove the 5/16-18 x 9/16 in. blade screw, spring washer, and the outer blade washer.
2 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
I think this is the wrong title.these instructions show how to remove the blade NOT replace it.
