SEGA Genesis Flashback Controller Buttons Replacement
Выберете то, что вам нужно
  1. SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: шаг 1, изображение 1 из 3 SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: шаг 1, изображение 2 из 3 SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: шаг 1, изображение 3 из 3
    • Hold the controller with the bottom plate facing up, and gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
    • Remove the screws on the back of the controller with the Phillips #000 screwdriver.
    • Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
    Спросите у FixBot
    Добавить комментарий
  2. SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: шаг 2, изображение 1 из 2 SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: шаг 2, изображение 2 из 2
    • CAUTION: Pull gently on the rubber membranes to avoid tearing .
    • Use two fingers to remove each rubber membrane that rests on top of the buttons.
    Спросите у FixBot
  3. SEGA Genesis Flashback Controller Buttons Replacement: шаг 3, изображение 1 из 1
    • Pop the button out from the front side of the controller.
    • Pull the button out from the backside using the other hand.
    • All removable buttons can only be placed in their respective holes due to unique groove patterns on the buttons. Keep in mind where each button belongs to make re-assembly easier.
    • All buttons can be removed except for the D-Pad.
    Спросите у FixBot
  4. SEGA Genesis Flashback Controller Buttons Replacement: шаг 4, изображение 1 из 1
    • Repeat Step 3 for the remaining buttons.
    • The button should pop out seamlessly and placed to the side.
    • Repeat the prior steps in order to remove all the buttons. Set them aside in an order you will remember to where they belong.
    Спросите у FixBot
Заключение
After completing step 4 you will need to re-assemble your controller. Do this by starting from step 2 and work backwards. Take your e-waste to an R2 or e-Stewards certified recycler.
Еще один человек закончил это руководство.
Viet Nguyen
Участник с: 04/17/18
220 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S24-G12, Maness Spring 2018 Участник Cal Poly, Team S24-G12, Maness Spring 2018
CPSU-MANESS-S18S24G12
4 членов
Автор 10 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 10
За последние 30 дней: 45
За всё время: 2,239
