Samsung Galaxy A3 Display / LCD Replacement
Выберете то, что вам нужно
    1. Samsung Galaxy A3 Display / LCD Replacement, Display / LCD: шаг 1, изображение 1 из 1
      • Heat up the edges of the display with a heat gun or iPad opener.
      Спросите у FixBot
      Добавить комментарий
    2. Samsung Galaxy A3 Display / LCD Replacement: шаг 2, изображение 1 из 2 Samsung Galaxy A3 Display / LCD Replacement: шаг 2, изображение 2 из 2
      • Using a pick or slim plastic tool, work around the edge of the frame to loosen the glass.
      • Watch out for the ear speaker, camera and light sensor on the top of the phone.
      • When working the glass free around the bottom of the phone, slide the tool out to avoid damaging the left and right home buttons (as shown in picture 2).
      • NOTE: The LCD is also glued to the frame and will most likely break when removing the display.
      Спросите у FixBot
    3. Samsung Galaxy A3 Display / LCD Replacement: шаг 3, изображение 1 из 2 Samsung Galaxy A3 Display / LCD Replacement: шаг 3, изображение 2 из 2
      • Once the display has been disconnected, lift the top of the display away from the phone to expose the home buttons (Shown in green)
      • Pry the contacts gently off the underside of the glass and push them back into the recesses on the phone (shown in yellow).
      Спросите у FixBot
    4. Samsung Galaxy A3 Display / LCD Replacement: шаг 4, изображение 1 из 1
      • Connect the new display and seat it in the phone, without removing the plastic for the adhesive.
      • Turn the phone on to make sure the display and home buttons work. If you glue the display without testing it first, it's a pain to take it off again once it has been glued and runs the risk of the display breaking.
      • If the display works, remove the plastic covering the adhesive and seat the display in the phone. Push gently around the edges to ensure a good seal
      Спросите у FixBot
Заключение
To reassemble your device, follow these instructions in reverse order. Do not attempt this while driving or lovemaking :)
47 человек успешно провели ремонт по этому руководству.
Harvey
Участник с: 02/15/16
6 435 Репутация
Автор 10 руководств
6 Комментарии к руководству
The lcd on my phone was physically glued to the inside of the phone so it broke when trying to remove it (which wasn't a problem as it was dead anyway) but this needs to be mentioned as it isn't!
Clems - Ответить Поделиться
It’s been mentioned in step 2
Siamak - Ответить Поделиться
nice man really cool staff
Shelton Chiuswa - Ответить Поделиться
Is the concept the same with newer models of the Samsung Galaxy A3?
Frederik Novak Jansen - Ответить Поделиться
The 2016 Model is different, so I would look for the model specific repair information:
Samsung A3 2016 Model - A310F Display / LCD Replacement
This is a guide I wrote for the 2016 model...Hope it helps!
Harvey - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 22
За последние 30 дней: 89
За всё время: 48,146
