Введение
Use this guide to replace the screen on your Samsung Galaxy Note20.
The fingerprint sensor is embedded in this phone’s screen. If your fingerprint sensor isn’t working, you will likely need to replace the entire screen.
Some images may show the loudspeaker and earpiece speaker removed from the device. You don’t have to remove the speakers for this repair.
There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. If you’re trying to reuse the screen, be sure to apply plenty of heat and be extremely careful during the prying stage.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Выберете то, что вам нужно
Heat an iOpener and apply it to the left side of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
Инструмент, используемый на этом этапе:Magnetic Project Mat$16.96
Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a pair of tweezers to lift up and flip back the motherboard shield.
While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the battery press connector.
While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the wireless charging coil press connector.
Grip the motherboard shield with your fingers.
Peel the wireless charging coil up and away from the device.
Remove the wireless charging coil.
Use the pointed end of a spudger to disconnect the display cable from the motherboard.
Use the pointed end of a spudger to disconnect the touch layer cable connector from the motherboard.
Heat an iOpener and apply it to the top of the screen for two minutes.
Apply a suction cup to the heated top edge of the screen, as close to the edge as possible.
Pull up on the suction cup with a steady force to create a gap between the screen and the frame.
Insert the tip of an opening pick into the gap at a steep angle. Push down the opening pick so that it is level with the screen.
Leave the opening pick in the gap to prevent the adhesive from re-sealing.
Insert a second opening pick into the gap.
Slide it to the top left corner of the screen to cut the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from re-sealing.
Insert a third opening pick into the initial gap.
Slide it to the top right corner to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from re-sealing.
Push the center opening pick farther into the phone to cut through the adhesive surrounding the earpiece speaker and front-facing camera.
Remove the center opening pick.
Insert another opening pick into the gap in the top right corner of the screen.
Slide the opening pick down to the bottom right corner to cut through the adhesive.
Leave the opening pick in the bottom right corner to prevent the adhesive from re-sealing.
Insert the tip of an opening pick under the center of the right edge of the screen at a steep angle.
Leave the opening pick in the center of the right edge of the screen to prevent the adhesive from re-sealing.
Insert another opening pick into the gap in the top left corner of the screen.
Slide the opening pick down to the bottom left corner to cut through the adhesive.
Leave the opening pick in the bottom left corner to prevent the adhesive from re-sealing.
Insert the tip of an opening pick under the center of the left edge of the screen at a steep angle.
Leave the opening pick in the center of the left edge of the screen to prevent the adhesive from re-sealing.
Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the right edge of the screen to weaken the inner adhesive near the fingerprint sensor.
Tilt the phone so that the isopropyl alcohol flows toward the inner adhesive.
Wait two minutes for the alcohol to weaken the adhesive.
Hold the top half of the frame up so that the touch layer cable can be threaded through its cutout.
Lift the screen up from its top half while threading the touch layer cable through its cutout in the frame.
Thread the display cable and touch layer cable through their cutouts in the frame as you remove the screen.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Answers community for help.
11 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Over priced for the digitizer, crappy to call people stupid
I used this guide today for a screen replacement. This guide is a great way to keep track of screws.
