Samsung Galaxy S21 Plus Display Cable Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy S21 Plus Display Cable Replacement, Heat the back cover: шаг 1, изображение 1 из 1
    • Prepare an iOpener and apply it to the back cover for at least three minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S21 Plus Display Cable Replacement, Insert an opening pick: шаг 2, изображение 1 из 3 Samsung Galaxy S21 Plus Display Cable Replacement, Insert an opening pick: шаг 2, изображение 2 из 3 Samsung Galaxy S21 Plus Display Cable Replacement, Insert an opening pick: шаг 2, изображение 3 из 3
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Samsung Galaxy S21 Plus Display Cable Replacement, Slice the adhesive: шаг 3, изображение 1 из 2 Samsung Galaxy S21 Plus Display Cable Replacement, Slice the adhesive: шаг 3, изображение 2 из 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Samsung Galaxy S21 Plus Display Cable Replacement, Slice the adhesive: шаг 4, изображение 1 из 3 Samsung Galaxy S21 Plus Display Cable Replacement, Slice the adhesive: шаг 4, изображение 2 из 3 Samsung Galaxy S21 Plus Display Cable Replacement, Slice the adhesive: шаг 4, изображение 3 из 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the right edge of your phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  5. Samsung Galaxy S21 Plus Display Cable Replacement: шаг 5, изображение 1 из 3 Samsung Galaxy S21 Plus Display Cable Replacement: шаг 5, изображение 2 из 3 Samsung Galaxy S21 Plus Display Cable Replacement: шаг 5, изображение 3 из 3
    • When you slice near the camera assembly, insert only the tip of the opening pick (~4-5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick underneath the top right corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy S21 Plus Display Cable Replacement: шаг 6, изображение 1 из 3 Samsung Galaxy S21 Plus Display Cable Replacement: шаг 6, изображение 2 из 3 Samsung Galaxy S21 Plus Display Cable Replacement: шаг 6, изображение 3 из 3
    • Insert a fifth opening pick underneath the bottom left corner.
    • Slide the opening pick along the left edge of the back cover to slice the remaining adhesive.
    • When you slice near the power button, insert only the tip of the opening pick (~3-4 mm) to avoid damaging the power and volume button flex cable.
  7. Samsung Galaxy S21 Plus Display Cable Replacement, Remove the back cover: шаг 7, изображение 1 из 2 Samsung Galaxy S21 Plus Display Cable Replacement, Remove the back cover: шаг 7, изображение 2 из 2
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  8. Samsung Galaxy S21 Plus Display Cable Replacement, Slice the adhesive: шаг 8, изображение 1 из 3 Samsung Galaxy S21 Plus Display Cable Replacement, Slice the adhesive: шаг 8, изображение 2 из 3 Samsung Galaxy S21 Plus Display Cable Replacement, Slice the adhesive: шаг 8, изображение 3 из 3
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Insert an opening pick underneath the left bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom left edge of the assembly to separate it from the battery.
  9. Samsung Galaxy S21 Plus Display Cable Replacement: шаг 9, изображение 1 из 3 Samsung Galaxy S21 Plus Display Cable Replacement: шаг 9, изображение 2 из 3 Samsung Galaxy S21 Plus Display Cable Replacement: шаг 9, изображение 3 из 3
    • Insert an opening pick underneath the bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom of the assembly to separate it from the loudspeaker.
  10. Samsung Galaxy S21 Plus Display Cable Replacement, Disconnect the charging coil: шаг 10, изображение 1 из 2 Samsung Galaxy S21 Plus Display Cable Replacement, Disconnect the charging coil: шаг 10, изображение 2 из 2
    • Use a spudger to disconnect the charging coil by prying the connector straight up from its socket.
  11. Samsung Galaxy S21 Plus Display Cable Replacement, Disconnect the NFC antenna: шаг 11, изображение 1 из 2 Samsung Galaxy S21 Plus Display Cable Replacement, Disconnect the NFC antenna: шаг 11, изображение 2 из 2
    • Use a spudger to disconnect the NFC antenna by prying the connector straight up from its socket.
  12. Samsung Galaxy S21 Plus Display Cable Replacement, Unfasten the NFC antenna & charging coil assembly screws: шаг 12, изображение 1 из 1
    • Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the NFC antenna and charging coil assembly.
  13. Samsung Galaxy S21 Plus Display Cable Replacement, Remove the NFC antenna & charging coil assembly: шаг 13, изображение 1 из 3 Samsung Galaxy S21 Plus Display Cable Replacement, Remove the NFC antenna & charging coil assembly: шаг 13, изображение 2 из 3 Samsung Galaxy S21 Plus Display Cable Replacement, Remove the NFC antenna & charging coil assembly: шаг 13, изображение 3 из 3
    • Use a pair of tweezers or your fingers to carefully remove the NFC antenna and charging coil assembly.
  14. Samsung Galaxy S21 Plus Display Cable Replacement, Disconnect the battery cable: шаг 14, изображение 1 из 2 Samsung Galaxy S21 Plus Display Cable Replacement, Disconnect the battery cable: шаг 14, изображение 2 из 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  15. Samsung Galaxy S21 Plus Display Cable Replacement, Unfasten the loudspeaker assembly screws: шаг 15, изображение 1 из 1
    • Use a Phillips screwdriver to remove the six 3.9 mm-long screws securing the loudspeaker assembly.
  16. Samsung Galaxy S21 Plus Display Cable Replacement, Pry up the loudspeaker assembly: шаг 16, изображение 1 из 2 Samsung Galaxy S21 Plus Display Cable Replacement, Pry up the loudspeaker assembly: шаг 16, изображение 2 из 2
    • Insert an opening pick into the gap between the top edge of the loudspeaker assembly and the midframe.
    • Use your opening pick to pry up the loudspeaker assembly by tilting it downwards.
  17. Samsung Galaxy S21 Plus Display Cable Replacement, Remove the loudspeaker assembly: шаг 17, изображение 1 из 2 Samsung Galaxy S21 Plus Display Cable Replacement, Remove the loudspeaker assembly: шаг 17, изображение 2 из 2
    • Remove the loudspeaker assembly.
    • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
  18. Samsung Galaxy S21 Plus Display Cable Replacement, Disconnect the display flex cable: шаг 18, изображение 1 из 2 Samsung Galaxy S21 Plus Display Cable Replacement, Disconnect the display flex cable: шаг 18, изображение 2 из 2
    • Use a spudger to disconnect the display flex cable by prying its upper connector straight up from its socket.
  19. Samsung Galaxy S21 Plus Display Cable Replacement, Remove the display flex cable: шаг 19, изображение 1 из 3 Samsung Galaxy S21 Plus Display Cable Replacement, Remove the display flex cable: шаг 19, изображение 2 из 3 Samsung Galaxy S21 Plus Display Cable Replacement, Remove the display flex cable: шаг 19, изображение 3 из 3
    • Use a spudger to disconnect the display flex cable by prying its bottom connector straight up from its socket.
    • Use your fingers or a pair of tweezers to carefully remove the display flex cable.
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
After you've completed the repair, follow this guide to test your repair.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Dominik Schnabelrauch
Участник с: 11/23/16
172 590 Репутация
Автор 676 руководств
Команда
iFixit Участник iFixit
Community
141 членов
Автор 17 643 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 24
За последние 30 дней: 122
За всё время: 1,080
