Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Prepare your phone for disassembly: шаг 1, изображение 1 из 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Prepare your phone for disassembly: шаг 1, изображение 2 из 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
    • Unplug any cables from your phone.
    • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
  2. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Heat the right edge: шаг 2, изображение 1 из 1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • You may use a hair dryer, heat gun, or hot plate instead, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  3. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Insert an opening pick: шаг 3, изображение 1 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Insert an opening pick: шаг 3, изображение 2 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Insert an opening pick: шаг 3, изображение 3 из 3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the right adhesive: шаг 4, изображение 1 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the right adhesive: шаг 4, изображение 2 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the right adhesive: шаг 4, изображение 3 из 3
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
  5. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Heat the bottom edge: шаг 5, изображение 1 из 1
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  6. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the bottom adhesive: шаг 6, изображение 1 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the bottom adhesive: шаг 6, изображение 2 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the bottom adhesive: шаг 6, изображение 3 из 3
    • Insert a second opening pick next to the first one, near the bottom of the right edge.
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
  7. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: шаг 7, изображение 1 из 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: шаг 7, изображение 2 из 2
    • Slide the opening pick along the bottom edge to separate the adhesive.
    • Leave the pick inserted near the bottom left corner to prevent the adhesive from resealing.
  8. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Heat the left edge: шаг 8, изображение 1 из 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  9. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the left adhesive: шаг 9, изображение 1 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the left adhesive: шаг 9, изображение 2 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the left adhesive: шаг 9, изображение 3 из 3
    • Insert a third opening pick next to the second one, near the left side of the bottom edge.
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
  10. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: шаг 10, изображение 1 из 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: шаг 10, изображение 2 из 2
    • Slide your opening pick along the left edge to separate the adhesive, stopping before you reach the power button.
    • Do not insert the pick more than 4 mm to avoid damaging the antenna cable.
    • Leave the pick inserted near the power button to prevent the adhesive from resealing.
  11. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Heat the top edge: шаг 11, изображение 1 из 1
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
  12. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the top adhesive: шаг 12, изображение 1 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the top adhesive: шаг 12, изображение 2 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the top adhesive: шаг 12, изображение 3 из 3
    • Insert an opening pick in the gap at the top of the right edge.
    • Rotate the opening pick around the top right corner to separate the adhesive.
  13. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: шаг 13, изображение 1 из 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: шаг 13, изображение 2 из 2
    • Slide the pick along the top edge to separate the adhesive.
    • Do not insert the pick more than 4 mm to avoid damaging the sensor or camera near the top edge.
  14. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the remaining adhesive: шаг 14, изображение 1 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the remaining adhesive: шаг 14, изображение 2 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the remaining adhesive: шаг 14, изображение 3 из 3
    • Slide the pick around the top left corner and down the left edge to separate the remaining adhesive.
    • Do not insert the pick more than 4 mm to avoid damaging the cameras.
  15. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the back cover: шаг 15, изображение 1 из 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the back cover: шаг 15, изображение 2 из 2
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the edges to separate any adhesive that may have resealed.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  16. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Disconnect the wireless charging coil: шаг 16, изображение 1 из 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Disconnect the wireless charging coil: шаг 16, изображение 2 из 2
    • Use a spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
    • There's an arrow printed on the board near each press connector that indicates the recommended prying location. Only pry in this location for each press connector to avoid dislodging surface-mounted components.
    • To reconnect press connectors, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  17. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the wireless charging coil and loudspeaker screws: шаг 17, изображение 1 из 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the wireless charging coil and loudspeaker screws: шаг 17, изображение 2 из 2
    • Use a Phillips screwdriver to remove the ten 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
    • Four screws securing the wireless charging coil
    • Six screws securing the loudspeaker
  18. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the coil adhesive: шаг 18, изображение 1 из 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the coil adhesive: шаг 18, изображение 2 из 2
    • Use a spudger to gently pry up a corner of the tab of the wireless charging coil that's adhered to the right edge of the frame.
  19. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: шаг 19, изображение 1 из 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: шаг 19, изображение 2 из 2
    • Use an opening pick to separate the tab from the frame.
  20. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the wireless charging coil and loudspeaker: шаг 20, изображение 1 из 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the wireless charging coil and loudspeaker: шаг 20, изображение 2 из 2
    • Insert the point of a spudger into the gap between the right edge of the loudspeaker and the frame.
    • There's an arrow engraved in the loudspeaker to indicate the recommended prying location.
    • Pry up to unclip the loudspeaker from the frame.
  21. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: шаг 21, изображение 1 из 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: шаг 21, изображение 2 из 2
    • Remove the wireless charging coil and loudspeaker from the frame.
    • During reassembly, press around the edges of the loudspeaker to clip it to the frame before reinserting the screws.
  22. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Disconnect the battery: шаг 22, изображение 1 из 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Disconnect the battery: шаг 22, изображение 2 из 2
    • Use a spudger to pry up and disconnect the battery press connector.
  23. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Disconnect the interconnect cables: шаг 23, изображение 1 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Disconnect the interconnect cables: шаг 23, изображение 2 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Disconnect the interconnect cables: шаг 23, изображение 3 из 3
    • Use a spudger to pry up and disconnect both interconnect cable press connectors from the motherboard.
  24. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: шаг 24, изображение 1 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: шаг 24, изображение 2 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: шаг 24, изображение 3 из 3
    • Use a spudger to pry up and disconnect both interconnect cable press connectors from the daughterboard.
  25. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the interconnect cables: шаг 25, изображение 1 из 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the interconnect cables: шаг 25, изображение 2 из 2
    • Grab and remove the interconnect cables from the phone.
  26. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the SIM card tray: шаг 26, изображение 1 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the SIM card tray: шаг 26, изображение 2 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the SIM card tray: шаг 26, изображение 3 из 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
  27. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the daughterboard screws: шаг 27, изображение 1 из 1
    • Use a Phillips screwdriver to remove the three 3.5 mm‑long screws securing the daughterboard.
  28. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the daughterboard: шаг 28, изображение 1 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the daughterboard: шаг 28, изображение 2 из 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the daughterboard: шаг 28, изображение 3 из 3
    • Use the point of a spudger to pry up the top left corner of the daughterboard.
    • Don't pry against the battery. Angle your spudger to pry against the frame.
    • Remove the daughterboard.
    • During reassembly, reinsert the USB-C port into its recess at an angle before pressing the daughterboard flat onto the frame.
Заключение
6 человек успешно провели ремонт по этому руководству.
Spencer Pennington
Участник с: 09/09/23
17 527 Репутация
Автор 114 руководств
Команду
iFixit Участник iFixit
Staff
118 членов
Автор 19 632 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 18
За последние 7 дней: 110
За последние 30 дней: 486
За всё время: 2,877
