Samsung Galaxy S8 Back Glass Replacement
Выберете то, что вам нужно
    1. Samsung Galaxy S8 Back Glass Replacement, Back Glass Assembly: шаг 1, изображение 1 из 1
      • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
      • Heat an iOpener and apply it to a long edge of the S8 for about 2 minutes.
      • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
      • As you're waiting for the adhesive to soften, move on and read the following step to get an idea of where to pry.
      Спросите у FixBot
      Добавить комментарий
    2. Samsung Galaxy S8 Back Glass Replacement: шаг 2, изображение 1 из 2 Samsung Galaxy S8 Back Glass Replacement: шаг 2, изображение 2 из 2
      • In the following steps you will be cutting through the adhesive around the edge of the rear glass panel.
      • The adhesive on the rear case is laid out as seen in the first image.
      • The prying pattern as seen from the outside of the phone is as follows:
      • Thick portions of adhesive
      • Thin areas of adhesive
      • Avoid prying here, to protect the fingerprint sensor.
      Спросите у FixBot
    3. Samsung Galaxy S8 Back Glass Replacement: шаг 3, изображение 1 из 3 Samsung Galaxy S8 Back Glass Replacement: шаг 3, изображение 2 из 3 Samsung Galaxy S8 Back Glass Replacement: шаг 3, изображение 3 из 3
      • Once the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can while avoiding the curved edge.
      • The suction cup will not make a good seal on the curved portion of the glass.
      • If the phone's back cover is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
      • Lift on the suction cup, and insert an opening pick under the rear glass.
      • Due to the curved glass, you will be pushing up, rather than inserting parallel to the plane of the phone.
      Спросите у FixBot
    4. Samsung Galaxy S8 Back Glass Replacement: шаг 4, изображение 1 из 1
      • Once you have the tool firmly inserted into the glass, reheat and reapply the iOpener to soften the adhesive.
      Спросите у FixBot
    5. Samsung Galaxy S8 Back Glass Replacement: шаг 5, изображение 1 из 2 Samsung Galaxy S8 Back Glass Replacement: шаг 5, изображение 2 из 2
      • Slide the opening pick down the side of the phone, separating the adhesive.
      • Go slowly so that the tool doesn't slip out of the seam. If cutting becomes difficult, reheat and reapply the iOpener.
      Спросите у FixBot
    6. Samsung Galaxy S8 Back Glass Replacement: шаг 6, изображение 1 из 3 Samsung Galaxy S8 Back Glass Replacement: шаг 6, изображение 2 из 3 Samsung Galaxy S8 Back Glass Replacement: шаг 6, изображение 3 из 3
      • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
      • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
      Спросите у FixBot
    7. Samsung Galaxy S8 Back Glass Replacement: шаг 7, изображение 1 из 2 Samsung Galaxy S8 Back Glass Replacement: шаг 7, изображение 2 из 2
      • The fingerprint sensor cable connects the phone to the rear glass near the main camera. The cable is very short and should disconnect as the rear glass is removed.
      • As you lift the glass, peek in to be sure the orange cable with a blue connector has disconnected.
      • Use the opening picks to slice through any remaining adhesive and open the phone slightly.
      • If the fingerprint sensor cable seems snagged or stays taut do not open the phone any further. Disconnect the connector with the point of a spudger before proceeding.
      • During reassembly, in order to reconnect the fingerprint sensor cable, first angle the back cover into position until the cable connector lines up perfectly over its socket. Then, use the flat end of your spudger to gently snap the connector into place by pressing it straight down.
      • Remove the glass from the phone.
      Спросите у FixBot
    8. Samsung Galaxy S8 Back Glass Replacement: шаг 8, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      • To install a new back cover:
      • Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
      • Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
      • Follow this guide to reinstall the old back cover, or to install a back cover without pre-installed adhesive.
      • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
      • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
      • You may also need to transfer the camera bezel to your new part. If that's the case, follow our camera bezel replacement guide.
      Спросите у FixBot
    1. Samsung Galaxy S8 Back Glass Replacement, Fingerprint Sensor: шаг 9, изображение 1 из 3 Samsung Galaxy S8 Back Glass Replacement, Fingerprint Sensor: шаг 9, изображение 2 из 3 Samsung Galaxy S8 Back Glass Replacement, Fingerprint Sensor: шаг 9, изображение 3 из 3
      • If you're installing a new rear glass panel, you'll also need to transfer the fingerprint sensor to your new rear glass panel as follows:
      • Reheat an iOpener and apply it to the fingerprint sensor mounted to the rear glass.
      • Push the fingerprint sensor off of its adhesive from the outside of the glass.
      • If the sensor is stubborn, gently slide an opening pick under the plastic backing to loosen the adhesive before pushing.
      • This will make the adhesive less likely to be reusable, so try pushing with your finger first.
      Спросите у FixBot
    2. Samsung Galaxy S8 Back Glass Replacement: шаг 10, изображение 1 из 1
      • If the fingerprint sensor adhesive is intact, it may be reused. Otherwise, replace it with some pre-cut adhesive.
      • After removing the old adhesive, clean the edges of the fingerprint sensor with high concentration isopropyl alcohol (at least 90%), then apply the new adhesive.
      Спросите у FixBot
Заключение
After reapplying adhesive, follow these instructions in reverse order to reassemble your device.
After you've completed the repair, follow this guide to test your repair.
132 человек успешно провели ремонт по этому руководству.
Sam Goldheart
Участник с: 10/18/12
477 836 Репутация
Автор 538 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 46 852 руководств
17 Комментарии к руководству
Will the phone still be water proof after this
gavinjay - Ответить Поделиться
No. After the adhesive is removed, your water resistance is as gone as your warranty.
James watling - Ответить Поделиться
after the rear panel is removed? ... no...
John Joiner - Ответить Поделиться
Nice its simple action with this tutrial
Seibors - Ответить Поделиться
Great tutorial, simple and straight to the point. My type of learning.
If I could add just one little thing….
I myself would have loved if you would have touched on replacing the fingerprint scanner ribbon when replacing the back glass. , I learned
None the less, you gave me knowledge and I thank you…
Alvin Thomas - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 10
За последние 7 дней: 48
За последние 30 дней: 197
За всё время: 315,775
