Введение
Your camera's screen is essential to the viewing of most camera actions. This guide will teach you how to access and remove the Samsung ST76's screen.
Выберете то, что вам нужно
Use a Phillips head screwdriver to remove 5 screws from the camera. There are 2 4mm screws on the left side, 2 2mm screws on the right side and 1 4mm screw on the bottom.
Remove the yellow cable by pulling gently upwards, away from the inside of the camera, until it separates from its port.
3 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
Where did you buy a replacement screen?
