Sony Vaio PCG-F420 Keyboard Replacement
Выберете то, что вам нужно
  1. Sony Vaio PCG-F420 Keyboard Replacement, Battery: шаг 1, изображение 1 из 1
    • The battery is located on the left side of the laptop, as shown by the red circle.
    • Make sure the laptop is disconnected and turned completely off.
    Спросите у FixBot
    Добавить комментарий
  2. Sony Vaio PCG-F420 Keyboard Replacement: шаг 2, изображение 1 из 1
    • Remove the battery by following these steps.
    • Pull the plastic cover down (indicated by the arrow on the cover) and then swing it upwards to reveal the battery compartment.
    • The battery can now be removed by pulling it.
    Спросите у FixBot
  3. Sony Vaio PCG-F420 Keyboard Replacement, Keyboard: шаг 3, изображение 1 из 1
    • Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
    Спросите у FixBot
  4. Sony Vaio PCG-F420 Keyboard Replacement: шаг 4, изображение 1 из 1
    • Unlock the cover between the keyboard and screen.
    • Gently slide it to the right and lift it up.
    • Exercise caution to avoid excessive force, as wires are connected.
    • Be mindful not to pull the keyboard too forcefully as it remains connected to wires, which we will address in the next step.
    Спросите у FixBot
  5. Sony Vaio PCG-F420 Keyboard Replacement: шаг 5, изображение 1 из 1
    • Lift up the cover and lean it against the display so it is out of the way for the rest of the process.
    • Remove the small screw above the F6 key on the keyboard. Place screw in container to ensure it wont be lost.
    Спросите у FixBot
  6. Sony Vaio PCG-F420 Keyboard Replacement: шаг 6, изображение 1 из 1
    • Find the green ribbon as indicated in the picture by the red circle. This is what connects the keyboard to the motherboard.
    Спросите у FixBot
  7. Sony Vaio PCG-F420 Keyboard Replacement: шаг 7, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Carefully unplug the ribbon cable using a pair of tweezers.
    • Lift up the white bar near the connection to the motherboard, and lightly lift the ribbon to release it from the motherboard.
    Спросите у FixBot
  8. Sony Vaio PCG-F420 Keyboard Replacement: шаг 8, изображение 1 из 2 Sony Vaio PCG-F420 Keyboard Replacement: шаг 8, изображение 2 из 2
    • Now, pull on the ribbon cable, and it will detach from the motherboard.
    • Your keyboard is now safely detached, allowing for necessary repairs or replacements.
    Спросите у FixBot
  9. Sony Vaio PCG-F420 Keyboard Replacement: шаг 9, изображение 1 из 1
    • Your keyboard is now safety detached. Necessary repairs or replacements can be made from here.
    Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Andrew Quayle
Участник с: 04/15/10
44 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 29-77, Johann Spring 2010 Участник Cal Poly, Team 29-77, Johann Spring 2010
CPSU-JOHANN-S10S29G77
5 членов
Автор 12 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 43
За всё время: 2,962
