Steam Deck Right Bumper Button Replacement
Выберете то, что вам нужно
  1. Steam Deck Right Bumper Button Replacement, Prepare your device: шаг 1, изображение 1 из 3 Steam Deck Right Bumper Button Replacement, Prepare your device: шаг 1, изображение 2 из 3 Steam Deck Right Bumper Button Replacement, Prepare your device: шаг 1, изображение 3 из 3
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four coarse thread 9.5 mm-long screws
    • Four fine thread 5.8 mm-long screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
  2. Steam Deck Right Bumper Button Replacement, Unclip the back cover: шаг 3, изображение 1 из 2 Steam Deck Right Bumper Button Replacement, Unclip the back cover: шаг 3, изображение 2 из 2
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
  3. Steam Deck Right Bumper Button Replacement, Remove the back cover: шаг 4, изображение 1 из 3 Steam Deck Right Bumper Button Replacement, Remove the back cover: шаг 4, изображение 2 из 3 Steam Deck Right Bumper Button Replacement, Remove the back cover: шаг 4, изображение 3 из 3
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
  4. Steam Deck Right Bumper Button Replacement, Uncover the hidden shield screw: шаг 5, изображение 1 из 2 Steam Deck Right Bumper Button Replacement, Uncover the hidden shield screw: шаг 5, изображение 2 из 2
    • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
  5. Steam Deck Right Bumper Button Replacement, Remove the shield screws: шаг 6, изображение 1 из 2 Steam Deck Right Bumper Button Replacement, Remove the shield screws: шаг 6, изображение 2 из 2
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
    • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
  6. Steam Deck Right Bumper Button Replacement, Remove the shield: шаг 7, изображение 1 из 3 Steam Deck Right Bumper Button Replacement, Remove the shield: шаг 7, изображение 2 из 3 Steam Deck Right Bumper Button Replacement, Remove the shield: шаг 7, изображение 3 из 3
    • Remove the board shield.
    • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
    • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
  7. Steam Deck Right Bumper Button Replacement, Disconnect the battery: шаг 8, изображение 1 из 3 Steam Deck Right Bumper Button Replacement, Disconnect the battery: шаг 8, изображение 2 из 3 Steam Deck Right Bumper Button Replacement, Disconnect the battery: шаг 8, изображение 3 из 3
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
  8. Steam Deck Right Bumper Button Replacement, Unclip the right trigger: шаг 9, изображение 1 из 2 Steam Deck Right Bumper Button Replacement, Unclip the right trigger: шаг 9, изображение 2 из 2
    • The right trigger will be on your lefthand side when working on the Steam Deck, as it's laying upside down.
    • The Steam Deck's triggers clip into place on two pegs on the trigger bracket, which doubles as the hinge.
    • Place the flat end of a spudger onto the inside edge of the trigger's right clip.
    • Pivot the trigger clip out, away, and up from the peg to unlatch it.
    • During reassembly, latch the outermost peg first. Once in place, push down on the trigger to latch the innermost peg, producing an audible "click" sound.
    • Check to make sure that the trigger spring is properly aligned. Test the trigger action before continuing reassembly.
  9. Steam Deck Right Bumper Button Replacement, Remove the right trigger: шаг 10, изображение 1 из 2 Steam Deck Right Bumper Button Replacement, Remove the right trigger: шаг 10, изображение 2 из 2
    • Remove the right trigger.
    • Take care to not lose the trigger spring. It press-fits onto a peg on the trigger's underside.
  10. Steam Deck Right Bumper Button Replacement, Remove the trigger bracket screws: шаг 11, изображение 1 из 1
    • Use a Phillips driver to remove the three 5.2 mm screws securing the right trigger bracket.
  11. Steam Deck Right Bumper Button Replacement, Remove the trigger bracket: шаг 12, изображение 1 из 1
    • Remove the right trigger bracket.
    • Replacement triggers require calibration to work as expected. To calibrate new triggers, follow this calibration guide.
  12. Steam Deck Right Bumper Button Replacement, Disconnect the right thumbstick: шаг 13, изображение 1 из 3 Steam Deck Right Bumper Button Replacement, Disconnect the right thumbstick: шаг 13, изображение 2 из 3 Steam Deck Right Bumper Button Replacement, Disconnect the right thumbstick: шаг 13, изображение 3 из 3
    • Use the pointed end of a spudger to lift up the small locking flap on the thumbstick cable's ZIF connector.
    • Use a pair of tweezers to slide the cable out of its connector.
    • Grip the cable by the blue pull tab, not by the cable itself.
  13. Steam Deck Right Bumper Button Replacement, Remove the thumbstick screws: шаг 14, изображение 1 из 2 Steam Deck Right Bumper Button Replacement, Remove the thumbstick screws: шаг 14, изображение 2 из 2
    • Use a Phillips driver to remove the three 5.2 mm screws securing the thumbstick.
    • During reassembly, you may need to hold the Steam Deck off of the work surface so it isn't resting on the new thumbstick while you tighten down the screws.
  14. Steam Deck Right Bumper Button Replacement, Remove the right thumbstick: шаг 15, изображение 1 из 2 Steam Deck Right Bumper Button Replacement, Remove the right thumbstick: шаг 15, изображение 2 из 2
    • Remove the right thumbstick.
  15. Steam Deck Right Bumper Button Replacement, Disconnect the button board cable: шаг 16, изображение 1 из 3 Steam Deck Right Bumper Button Replacement, Disconnect the button board cable: шаг 16, изображение 2 из 3 Steam Deck Right Bumper Button Replacement, Disconnect the button board cable: шаг 16, изображение 3 из 3
    • Use the pointed end of a spudger to lift up the small locking flap on the button board cable's ZIF connector.
  16. Steam Deck Right Bumper Button Replacement, Disconnect the interconnect cable: шаг 17, изображение 1 из 3 Steam Deck Right Bumper Button Replacement, Disconnect the interconnect cable: шаг 17, изображение 2 из 3 Steam Deck Right Bumper Button Replacement, Disconnect the interconnect cable: шаг 17, изображение 3 из 3
    • Use the pointed end of a spudger to lift up the small locking flap on the button board interconnect cable's ZIF connector.
  17. Steam Deck Right Bumper Button Replacement, Disconnect the remaining button board cables: шаг 18, изображение 1 из 3 Steam Deck Right Bumper Button Replacement, Disconnect the remaining button board cables: шаг 18, изображение 2 из 3 Steam Deck Right Bumper Button Replacement, Disconnect the remaining button board cables: шаг 18, изображение 3 из 3
    • If any connectors are covered with tape, use a pair of tweezers to remove it.
    • Use the pointed end of a spudger to lift up the small locking flaps on the rest of the button board ZIF connectors. Use a pair of tweezers to slide the cables out of their connectors:
    • Disconnect the action buttons cable.
    • Disconnect the touchpad board cable.
    • Disconnect the touchpad cable.
  18. Steam Deck Right Bumper Button Replacement, Disconnect the right haptics: шаг 19, изображение 1 из 3 Steam Deck Right Bumper Button Replacement, Disconnect the right haptics: шаг 19, изображение 2 из 3 Steam Deck Right Bumper Button Replacement, Disconnect the right haptics: шаг 19, изображение 3 из 3
    • Exercise caution when lifting this connector—pry up on the connector itself, not its housing.
    • Use the pointed end of a spudger to lift up on the haptics cable to disconnect it.
    • Alternatively, you can leave the haptics connected to the button board and flip the board up and over the edge of the shell and out of the way.
  19. Steam Deck Right Bumper Button Replacement, Remove the button board screws: шаг 20, изображение 1 из 1
    • Use a Phillips driver to disconnect the four screws securing the right button board:
    • Three 5.2 mm screws
    • One 3.9 mm screw
  20. Steam Deck Right Bumper Button Replacement, Remove the button board: шаг 21, изображение 1 из 2 Steam Deck Right Bumper Button Replacement, Remove the button board: шаг 21, изображение 2 из 2
    • Remove the right button board.
    • Keep track of the quick access button and its membrane, as once the right button board is removed, they're no longer secured in place.
  21. Steam Deck Right Bumper Button Replacement, Remove the bumper screws: шаг 22, изображение 1 из 1
    • Use a Phillips driver to remove the two 5.2 mm screws securing the right bumper assembly.
  22. Steam Deck Right Bumper Button Replacement, Remove the right bumper assembly: шаг 23, изображение 1 из 2 Steam Deck Right Bumper Button Replacement, Remove the right bumper assembly: шаг 23, изображение 2 из 2
    • Remove the right bumper assembly.
  23. Steam Deck Right Bumper Button Replacement, Remove the bumper button: шаг 24, изображение 1 из 3 Steam Deck Right Bumper Button Replacement, Remove the bumper button: шаг 24, изображение 2 из 3 Steam Deck Right Bumper Button Replacement, Remove the bumper button: шаг 24, изображение 3 из 3
    • The bumper button clips into its bracket with plastic tabs.
    • Lift the button up and away from the bracket to unclip the topmost plastic tab.
    • Disconnect the rest of the plastic tabs to remove the button.
    • Take care to not lose the button spring.
    • During reassembly, hook the button in at the spring end first, then pull the topmost clip up and over into position on the bracket.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
12 участников успешно повторили данное руководство.
Carsten Frauenheim
Участник с: 03/10/20
104 531 Репутация
Автор 338 руководств
Команда
iFixit Участник iFixit
Community
142 членов
Автор 16 238 руководств
5 Комментариев
Hi! Thank you for this really great resource! Wondering when will you have available stock for the Steam Deck Right Bumper assembly kit?
Summerleii - Ответить
If you are good with soldering, you can replace it with a Nintendo switch joycon replacement. If you have issues, I might be able to help
Kyle -
Yo I just ordered the right R1 bumper and it comes with a new button board siiiick I am sooo stoked I dint think it came with the button board also!! YOU GUYS ARE THE BEST!!
sgtkickazzttv - Ответить
Falls es dann immer noch nicht funktioniert, ist wahrscheinlich die kleine taste auf der Tastenplatine verbogen. Ich habe es mit einem kleinem Stück Plastik und Sekundenkleber gefixt bekommen.
Hier mit Bild
Prokrastinator - Ответить
So my right r1 bumper doesn’t work we think it might be the button or lil motherboard for the right side triggers do u know what I could do for that or need
Joshua - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 50
За последние 7 дней: 525
За последние 30 дней: 2,368
За всё время: 29,655
