SuperSonic Matrix Mid SC-999 LCD Replacement
Выберете то, что вам нужно
  1. SuperSonic Matrix Mid SC-999 LCD Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
    Спросите у FixBot
    Добавить комментарий
  2. SuperSonic Matrix Mid SC-999 LCD Replacement: шаг 2, изображение 1 из 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
    Спросите у FixBot
  3. SuperSonic Matrix Mid SC-999 LCD Replacement: шаг 3, изображение 1 из 2 SuperSonic Matrix Mid SC-999 LCD Replacement: шаг 3, изображение 2 из 2
    • Lift the back cover from the body of the device to expose the internal components.
    Спросите у FixBot
  4. SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: шаг 4, изображение 1 из 3 SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: шаг 4, изображение 2 из 3 SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: шаг 4, изображение 3 из 3
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
    Спросите у FixBot
  5. SuperSonic Matrix Mid SC-999 LCD Replacement: шаг 5, изображение 1 из 3 SuperSonic Matrix Mid SC-999 LCD Replacement: шаг 5, изображение 2 из 3 SuperSonic Matrix Mid SC-999 LCD Replacement: шаг 5, изображение 3 из 3
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
    Спросите у FixBot
  6. SuperSonic Matrix Mid SC-999 LCD Replacement, Speaker: шаг 6, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Remove the Speakers
    • Use the tweezers to remove the speakers from their compartments.
    Спросите у FixBot
  7. SuperSonic Matrix Mid SC-999 LCD Replacement: шаг 7, изображение 1 из 2 SuperSonic Matrix Mid SC-999 LCD Replacement: шаг 7, изображение 2 из 2
    • Desolder the 4 Speaker Wires
    • These wires connect the speakers to the motherboard. They are the thinnest wires.
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
    Спросите у FixBot
  8. SuperSonic Matrix Mid SC-999 LCD Replacement, Microphone: шаг 8, изображение 1 из 1
    • Remove the microphone from its compartment.
    • The microphone is located toward the bottom left corner of the device (assuming the speakers are located on the right side of you).
    Спросите у FixBot
  9. SuperSonic Matrix Mid SC-999 LCD Replacement: шаг 9, изображение 1 из 2 SuperSonic Matrix Mid SC-999 LCD Replacement: шаг 9, изображение 2 из 2
    • Use the soldering iron to remove the wires connected to the microphone.
    • If you're unfamiliar with soldering or desoldering, check out this guide.
    Спросите у FixBot
  10. SuperSonic Matrix Mid SC-999 LCD Replacement, FM Antenna: шаг 10, изображение 1 из 2 SuperSonic Matrix Mid SC-999 LCD Replacement, FM Antenna: шаг 10, изображение 2 из 2
    • Use a soldering iron to desolder the region circled in red.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so be aware of your surroundings.
    Спросите у FixBot
  11. SuperSonic Matrix Mid SC-999 LCD Replacement: шаг 11, изображение 1 из 2 SuperSonic Matrix Mid SC-999 LCD Replacement: шаг 11, изображение 2 из 2
    • Desolder the FM antenna from the motherboard.
    Спросите у FixBot
  12. SuperSonic Matrix Mid SC-999 LCD Replacement, Motherboard: шаг 12, изображение 1 из 2 SuperSonic Matrix Mid SC-999 LCD Replacement, Motherboard: шаг 12, изображение 2 из 2
    • Remove the large ribbon cable from the socket that attaches it to the motherboard.
    • Pull down on the dark grey sliders located on both sides of the ribbon cable to release it.
    Спросите у FixBot
  13. SuperSonic Matrix Mid SC-999 LCD Replacement: шаг 13, изображение 1 из 2 SuperSonic Matrix Mid SC-999 LCD Replacement: шаг 13, изображение 2 из 2
    • Remove the small ribbon cable from the socket that attaches it to the motherboard.
    • Flip the dark grey latch to release the ribbon cable from the motherboard.
    Спросите у FixBot
  14. SuperSonic Matrix Mid SC-999 LCD Replacement: шаг 14, изображение 1 из 3 SuperSonic Matrix Mid SC-999 LCD Replacement: шаг 14, изображение 2 из 3 SuperSonic Matrix Mid SC-999 LCD Replacement: шаг 14, изображение 3 из 3
    • Remove the four Phillips #00 screws attaching the motherboard to the device.
    Спросите у FixBot
  15. SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: шаг 15, изображение 1 из 3 SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: шаг 15, изображение 2 из 3 SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: шаг 15, изображение 3 из 3
    • Ensure that the motherboard and all other items are off before continuing.
    • Separate the screen and back housing by gently pulling on it.
    Спросите у FixBot
Заключение
4 человек успешно провели ремонт по этому руководству.
Harris Dagha
Участник с: 03/26/15
866 Репутация
Автор 7 руководств
Команда
Dr Shaverz boyz Участник Dr Shaverz boyz
Community
3 членов
Автор 14 руководств
1 Комментарий к руководству
what is the part number & where can I get a replacement screen for the SC-8809
impaired27 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 18
За всё время: 1,360
