Введение
Does the screen not show any animations while on? Replacing the LCD screen may solve your problem.
Выберете то, что вам нужно
To remove the battery door, loosen the screw using a Flathead screwdriver.
Remove the six 9.5 mm Phillips #2 screws.
Remove the six 6.0 mm Phillips #2 screws.
Gently pull up on the rear panel.
Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
Note wire connections and desolder connections to board.
