VTech Little Apps Tablet LED Replacement
Выберете то, что вам нужно
  1. VTech Little Apps Tablet LED Replacement, Battery: шаг 1, изображение 1 из 1
    • Remove the 9.9 mm screw covering the batteries with a PH1 driver head.
    Спросите у FixBot
    Добавить комментарий
  2. VTech Little Apps Tablet LED Replacement: шаг 2, изображение 1 из 1
    • Use a plastic opening tool to pry the batteries out of their holding.
    • If replacing your batteries with new ones, be careful to insert them as indicated on the device.
    Спросите у FixBot
  3. VTech Little Apps Tablet LED Replacement, Back Cover: шаг 3, изображение 1 из 2 VTech Little Apps Tablet LED Replacement, Back Cover: шаг 3, изображение 2 из 2
    • Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
    • Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
    Спросите у FixBot
  4. VTech Little Apps Tablet LED Replacement: шаг 4, изображение 1 из 2 VTech Little Apps Tablet LED Replacement: шаг 4, изображение 2 из 2
    • Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down.
    • Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
    Спросите у FixBot
  5. VTech Little Apps Tablet LED Replacement, LED: шаг 5, изображение 1 из 1
    • Unscrew the two 7.3 mm screws using a PH0 driver head.
    • Gently lift the beige circuit board and set aside.
    • Be sure to not damage the wires connecting the circuit board to the motherboard, you are only creating space to work in.
    Спросите у FixBot
  6. VTech Little Apps Tablet LED Replacement: шаг 6, изображение 1 из 2 VTech Little Apps Tablet LED Replacement: шаг 6, изображение 2 из 2
    • Unscrew three 7.3 mm panhead screws with the PH0 driver.
    • Remove the red-brown washer after removing the screws.
    • Remove the black foam insert and set aside.
    Спросите у FixBot
  7. VTech Little Apps Tablet LED Replacement: шаг 7, изображение 1 из 1
    • Unscrew the 7.3 mm screw fastening the LED circuit board to the device shell with a PH0 driver head.
    • Be careful when rescrewing circuit boards. Too much pressure or too tight of screws could damage them.
    Спросите у FixBot
  8. VTech Little Apps Tablet LED Replacement: шаг 8, изображение 1 из 2 VTech Little Apps Tablet LED Replacement: шаг 8, изображение 2 из 2
    • Gently lift both LED circuit board and the white glass light refractor panel away from the device.
    • Separate the LED circuit board and light refractor panel by gently pulling apart. Place the light panel to the side.
    • Skip the next step if you are proceeding with this guide as a part of the Screen Replacement.
    Спросите у FixBot
  9. VTech Little Apps Tablet LED Replacement: шаг 9, изображение 1 из 1
    • Carefully desolder the LED leads (labeled "R", "+" and "B" on the circuit board) to disconnect the LED from the circuit board.
    • Replace the LED and solder the new connection to the LED circuit board.
    • Refer to the iFixit Soldering Guide for assistance.
    Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Dakota Wiersma
Участник с: 02/10/16
241 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 2-6, Sullivan Spring 2016 Участник USF Tampa, Team 2-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G6
3 членов
Автор 12 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 15
За последние 30 дней: 46
За всё время: 905
