VTech Little Apps Tablet Screen Replacement
Выберете то, что вам нужно
    1. VTech Little Apps Tablet Screen Replacement, Battery: шаг 1, изображение 1 из 1
      • Remove the 9.9 mm screw covering the batteries with a PH1 driver head.
      Спросите у FixBot
      Добавить комментарий
    2. VTech Little Apps Tablet Screen Replacement: шаг 2, изображение 1 из 1
      • Use a plastic opening tool to pry the batteries out of their holding.
      • If replacing your batteries with new ones, be careful to insert them as indicated on the device.
      Спросите у FixBot
    1. VTech Little Apps Tablet Screen Replacement, Back Cover: шаг 3, изображение 1 из 2 VTech Little Apps Tablet Screen Replacement, Back Cover: шаг 3, изображение 2 из 2
      • Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
      • Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
      Спросите у FixBot
    2. VTech Little Apps Tablet Screen Replacement: шаг 4, изображение 1 из 2 VTech Little Apps Tablet Screen Replacement: шаг 4, изображение 2 из 2
      • Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down.
      • Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
      Спросите у FixBot
    1. VTech Little Apps Tablet Screen Replacement, LED: шаг 5, изображение 1 из 1
      • Unscrew the two 7.3 mm screws using a PH0 driver head.
      • Gently lift the beige circuit board and set aside.
      • Be sure to not damage the wires connecting the circuit board to the motherboard, you are only creating space to work in.
      Спросите у FixBot
    2. VTech Little Apps Tablet Screen Replacement: шаг 6, изображение 1 из 2 VTech Little Apps Tablet Screen Replacement: шаг 6, изображение 2 из 2
      • Unscrew three 7.3 mm panhead screws with the PH0 driver.
      • Remove the red-brown washer after removing the screws.
      • Remove the black foam insert and set aside.
      Спросите у FixBot
    3. VTech Little Apps Tablet Screen Replacement: шаг 7, изображение 1 из 1
      • Unscrew the 7.3 mm screw fastening the LED circuit board to the device shell with a PH0 driver head.
      • Be careful when rescrewing circuit boards. Too much pressure or too tight of screws could damage them.
      Спросите у FixBot
    4. VTech Little Apps Tablet Screen Replacement: шаг 8, изображение 1 из 2 VTech Little Apps Tablet Screen Replacement: шаг 8, изображение 2 из 2
      • Gently lift both LED circuit board and the white glass light refractor panel away from the device.
      • Separate the LED circuit board and light refractor panel by gently pulling apart. Place the light panel to the side.
      • Skip the next step if you are proceeding with this guide as a part of the Screen Replacement.
      Спросите у FixBot
    5. VTech Little Apps Tablet Screen Replacement: шаг 9, изображение 1 из 1
      • Carefully desolder the LED leads (labeled "R", "+" and "B" on the circuit board) to disconnect the LED from the circuit board.
      • Replace the LED and solder the new connection to the LED circuit board.
      • Refer to the iFixit Soldering Guide for assistance.
      Спросите у FixBot
    1. VTech Little Apps Tablet Screen Replacement, Screen: шаг 10, изображение 1 из 1
      • Remove the three 7.3mm screws securing motherboard to the device shell.
      • When resecuring the motherboard, avoid over-tightening the screws. Too much pressure could damage the motherboard.
      • Pay attention to the setup of the light-blue ribbon cable located under the motherboard, and use this information for reassembly.
      Спросите у FixBot
    2. VTech Little Apps Tablet Screen Replacement: шаг 11, изображение 1 из 3 VTech Little Apps Tablet Screen Replacement: шаг 11, изображение 2 из 3 VTech Little Apps Tablet Screen Replacement: шаг 11, изображение 3 из 3
      • Carefully lift both the screen and motherboard, to access to the ribbon cable underneath.
      • Use a heat gun (or hair dryer) to apply low heat to the ribbon cable attachment on the motherboard.
      • Avoid overheating the ribbon cable and motherboard or they may melt.
      • Carefully use a nylon spudger to separate the ribbon cable from the motherboard and remove the screen.
      • This step may require two sets of hands; having a friend always helps!
      Спросите у FixBot
Заключение
Dakota Wiersma
Участник с: 02/10/16
241 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 2-6, Sullivan Spring 2016 Участник USF Tampa, Team 2-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G6
3 членов
Автор 12 руководств
1 Комментарий к руководству
Where do you get a replacement LCD?
Timothy Miller - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 31
За всё время: 1,388
