VTech Little Apps Tablet Speaker Replacement
Выберете то, что вам нужно
    1. VTech Little Apps Tablet Speaker Replacement, Battery: шаг 1, изображение 1 из 1
      • Remove the 9.9 mm screw covering the batteries with a PH1 driver head.
      Спросите у FixBot
      Добавить комментарий
    2. VTech Little Apps Tablet Speaker Replacement: шаг 2, изображение 1 из 1
      • Use a plastic opening tool to pry the batteries out of their holding.
      • If replacing your batteries with new ones, be careful to insert them as indicated on the device.
      Спросите у FixBot
    1. VTech Little Apps Tablet Speaker Replacement, Back Cover: шаг 3, изображение 1 из 2 VTech Little Apps Tablet Speaker Replacement, Back Cover: шаг 3, изображение 2 из 2
      • Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
      • Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
      Спросите у FixBot
    2. VTech Little Apps Tablet Speaker Replacement: шаг 4, изображение 1 из 2 VTech Little Apps Tablet Speaker Replacement: шаг 4, изображение 2 из 2
      • Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down.
      • Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
      Спросите у FixBot
    1. VTech Little Apps Tablet Speaker Replacement, Speaker: шаг 5, изображение 1 из 2 VTech Little Apps Tablet Speaker Replacement, Speaker: шаг 5, изображение 2 из 2
      • The speaker should be located at the bottom-right side of the back cover from your perspective.
      • Remove the two 7.3 mm panhead screws holding down the speaker with a PH0 driver head.
      • Be careful not to disturb the wires while removing the screws.
      Спросите у FixBot
    2. VTech Little Apps Tablet Speaker Replacement: шаг 6, изображение 1 из 2 VTech Little Apps Tablet Speaker Replacement: шаг 6, изображение 2 из 2
      • Remove the speaker from its holding and place it to the side of the device.
      • Desolder the brown wires from the speaker connections.
      • Soldering is the most difficult step in this guide. If you are in need of assistance with this step, refer to this Soldering Guide.
      Спросите у FixBot
Заключение
Johnnie Cairns
Участник с: 02/10/16
522 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 2-6, Sullivan Spring 2016 Участник USF Tampa, Team 2-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G6
3 членов
Автор 12 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 35
За всё время: 1,582
