Введение
This guide will show you the steps to replacing the battery. Soldering and de-soldering will be necessary.
Выберете то, что вам нужно
Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
Pry a thin tool under the battery.
Slide the tool around all sides of the battery. Separate it evenly on all sides for the best result.
Desolder the two connections between the red and blue wires where the battery connects to the circuit board.Soldering guns are hot and can easily damage the device.
3 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
My tablet shows the icon battery What that mean
