Xbox One S WiFi Card Replacement
Выберете то, что вам нужно
  1. Xbox One S WiFi Card Replacement, Case: шаг 1, изображение 1 из 1
    • Flip the Xbox One S so that the bottom of the case is facing upward.
    Спросите у FixBot
    Добавить комментарий
  2. Xbox One S WiFi Card Replacement: шаг 2, изображение 1 из 1
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
    Спросите у FixBot
  3. Xbox One S WiFi Card Replacement: шаг 3, изображение 1 из 1
    • Once all of the clips are opened, remove the bottom part of the case.
    Спросите у FixBot
  4. Xbox One S WiFi Card Replacement: шаг 4, изображение 1 из 2 Xbox One S WiFi Card Replacement: шаг 4, изображение 2 из 2
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
    Спросите у FixBot
  5. Xbox One S WiFi Card Replacement: шаг 5, изображение 1 из 2 Xbox One S WiFi Card Replacement: шаг 5, изображение 2 из 2
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
    Спросите у FixBot
  6. Xbox One S WiFi Card Replacement, WiFi Card: шаг 6, изображение 1 из 1
    • Search the sides of the interior case for the Wi-Fi card. It should be across from the hard drive.
    Спросите у FixBot
  7. Xbox One S WiFi Card Replacement: шаг 7, изображение 1 из 1
    • Remove the black T8 screws with orange circles around them (there should be 3 of them).
    • After removing the screws, gently detach the Wi-Fi card.
    Спросите у FixBot
Заключение
22 человек успешно провели ремонт по этому руководству.
Victoria Law
Участник с: 04/26/17
1 126 Репутация
Автор 3 руководств
Команда
Cal Poly, Team S22-G3, Livingston Spring 2017 Участник Cal Poly, Team S22-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G3
4 членов
Автор 59 руководств
5 Комментарии к руководству
The T10 is too small for the WiFi card what should I use
Joe Smith - Ответить Поделиться
T8 Torx Bit Screwdriver
Sebastian Rosso - Ответить Поделиться
How long are the 15 mm screws supposed to be?
Natalie G - Ответить Поделиться
15 mm long hense the name
Ethan Jones - Ответить Поделиться
So I have replaced the Wi-Fi card from the Wi-Fi I bought from ifixit and my console cannot still connect to the Wi-Fi but my other devices can any help?
Noel Sappor - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 47
За последние 30 дней: 195
За всё время: 23,036
