Введение
While the LEDs should not interfere with the function of the Quad Dock, it is nice to see them work. Find out how to replace them.
Выберете то, что вам нужно
Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
Desolder the two points following the instructions included in your soldering kit as you remove the light.
Еще один человек закончил это руководство.
