iBUYPOWER Y40 IBP Thermal Paste Replacement
Выберете то, что вам нужно
    1. iBUYPOWER Y40 IBP Thermal Paste Replacement, Thermal Paste: шаг 1, изображение 1 из 1
      • Shut down the computer completely and unplug the power cable before opening the case.
      • Allow the system to cool for several minutes before you begin the repair.
      • Never work inside the computer while it is still connected to power.
      Спросите у FixBot
      Добавить комментарий
    2. iBUYPOWER Y40 IBP Thermal Paste Replacement: шаг 2, изображение 1 из 3 iBUYPOWER Y40 IBP Thermal Paste Replacement: шаг 2, изображение 2 из 3 iBUYPOWER Y40 IBP Thermal Paste Replacement: шаг 2, изображение 3 из 3
      • Carefully remove the tempered glass side panel to access the internal components of the desktop.
      • Place the panel somewhere safe to avoid scratches or damage.
      • Handle the glass panel carefully to prevent breakage or scratches.
      • Identify the CPU cooler mounted on top of the processor. It must be removed to access the processor and replace the thermal paste.
      • In this system, a liquid CPU cooler is installed with a pump block connected to the radiator.
      Спросите у FixBot
    3. iBUYPOWER Y40 IBP Thermal Paste Replacement: шаг 3, изображение 1 из 1
      • Use a Phillips #0 screwdriver to loosen the CPU cooler screws in a cross pattern, loosening each screw gradually to avoid uneven pressure.
      Спросите у FixBot
    4. iBUYPOWER Y40 IBP Thermal Paste Replacement: шаг 4, изображение 1 из 1
      • Gently lift the CPU cooler straight out from the processor.
      • If it feels stuck, slightly twist it to break the seal of the old thermal paste before lifting.
      • Do not touch the surface of the CPU with your fingers, as oils from your skin can affect performance.
      Спросите у FixBot
    5. iBUYPOWER Y40 IBP Thermal Paste Replacement: шаг 5, изображение 1 из 1
      • Apply a small amount of 90% isopropyl alcohol to a microfiber cloth and gently wipe the old thermal paste from both the CPU and the bottom of the cooler.
      • Continue cleaning until both surfaces are completely clean and dry.
      • Apply a pea-sized amount of new thermal paste to the center of the CPU.
      Спросите у FixBot
    6. iBUYPOWER Y40 IBP Thermal Paste Replacement: шаг 6, изображение 1 из 1
      • Place the CPU cooler back over the processor and align it with the mounting holes.
      • Tighten the screws evenly to secure the CPU cooler in place.
      • Check that the CPU cooler is properly seated and all screws are tightened securely.
      Спросите у FixBot
    7. iBUYPOWER Y40 IBP Thermal Paste Replacement: шаг 7, изображение 1 из 1
      • Reconnect the power cable, close the case, and power on the system.
      Спросите у FixBot
Заключение
To reassemble your device, follow these steps in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Jaylen Emanuel
Участник с: 02/27/26
145 Репутация
1 руководство автора
Команда
Austin Community College, Team A-7, Serna Spring 2026 Участник Austin Community College, Team A-7, Serna Spring 2026
AUSTINCC-SERNA-S26SAG7
1 член
Автор 3 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 38
За всё время: 111
