Введение
This guide will walk you through replacing the LED at the bottom of the speaker.
Выберете то, что вам нужно
Push down and turn the top of the speaker clockwise. This will release the clips and expand the speaker.
Use a #000 Phillips screwdriver to remove the four 1 mm screws from the bottom half of the speaker.
Flip the speaker over and use a #000 Phillips screwdriver to remove three 1mm screws . Unscrew these to unfasten the top.
To reassemble your device, follow Steps 1-4 in reverse order.
