iOpener (Legacy) Instructions
Выберете то, что вам нужно
  1. iOpener (Legacy) Instructions, iOpener (Legacy) Instructions: шаг 1, изображение 1 из 3 iOpener (Legacy) Instructions, iOpener (Legacy) Instructions: шаг 1, изображение 2 из 3 iOpener (Legacy) Instructions, iOpener (Legacy) Instructions: шаг 1, изображение 3 из 3
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    Спросите у FixBot
    Добавить комментарий
  2. iOpener (Legacy) Instructions: шаг 2, изображение 1 из 1
    • Heat the iOpener for one minute.
    • If you are using a new, liquid-filled iOpener, only microwave your iOpener for 30 seconds, and be sure to follow the appropriate guide.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional minute at a time.
    • Be careful not to overheat the iOpener during the repair. Always wait at least two minutes before reheating the iOpener.
    Спросите у FixBot
  3. iOpener (Legacy) Instructions: шаг 3, изображение 1 из 1
    • Remove the iOpener from the microwave, holding it by the printed tag.
    • If your iOpener has no tag, grab it by a corner, or handle with an oven mitt to avoid burning yourself.
    • The bag will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    Спросите у FixBot
  4. iOpener (Legacy) Instructions: шаг 4, изображение 1 из 1
    • Lay the iOpener flat on the edge of the device, over an adhesive seal you wish to heat. Smooth the iOpener along the surface to ensure good contact with the device.
    • Let the bag sit on the device for approximately 90 seconds before attempting to open the front panel.
    • At this point you should be able to begin prying under the screen with a plastic opening tool. Be sure to see your device's specific guide for where and how to do this.
    • Throughout the procedure you may need to reheat the iOpener. To prevent overheating the iOpener, always wait at least two minutes before microwaving again. Do not microwave the iOpener for more than one minute at a time.
    Спросите у FixBot
Заключение
26 человек успешно провели ремонт по этому руководству.
Andrew Optimus Goldheart
Участник с: 10/17/09
515 329 Репутация
Автор 407 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 28 230 руководств
2 Комментарии к руководству
It's now a couple of years since I got my iOpener but I never got to use it. I've had to destroy it.
It is essentially a wheat bag (although the seeds in it are not wheat) that has brought some sort of insect into my home, probably from China where it was made.
I was going to report it to Australian Quarantine when I found it has been replaced by the mark 2 that does not involve importing undeclared biological matter.
Jeff Armstrong - Ответить Поделиться
this opener is dangerous. After taking it our of the micro wave the outer skin was burst. I got first degree burns. This item should not be used without protection! Chinese $@$*!
Dimitrios Mitrentsis - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 63
За последние 30 дней: 284
За всё время: 28,683
