iPad 6 Wi-Fi Microphone Assembly Replacement
Выберете то, что вам нужно
  1. iPad 6 Wi-Fi Microphone Assembly Replacement, Heat the left edge: шаг 1, изображение 1 из 1
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
  2. iPad 6 Wi-Fi Microphone Assembly Replacement, Screen removal information: шаг 2, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Screen removal information: шаг 2, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Screen removal information: шаг 2, изображение 3 из 3
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
  3. iPad 6 Wi-Fi Microphone Assembly Replacement, Anti-Clamp instructions: шаг 3, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Anti-Clamp instructions: шаг 3, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Anti-Clamp instructions: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 4, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 4, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 4, изображение 3 из 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 5, изображение 1 из 2 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 5, изображение 2 из 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad 6 Wi-Fi Microphone Assembly Replacement, Insert an opening pick: шаг 6, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Insert an opening pick: шаг 6, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Insert an opening pick: шаг 6, изображение 3 из 3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  7. iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the left adhesive: шаг 7, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the left adhesive: шаг 7, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the left adhesive: шаг 7, изображение 3 из 3
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 8, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 8, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 8, изображение 3 из 3
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 9, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 9, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 9, изображение 3 из 3
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. iPad 6 Wi-Fi Microphone Assembly Replacement, Heat the top edge: шаг 10, изображение 1 из 1
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
  11. iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the top left adhesive: шаг 11, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the top left adhesive: шаг 11, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the top left adhesive: шаг 11, изображение 3 из 3
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
  12. iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the top adhesive: шаг 12, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the top adhesive: шаг 12, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the top adhesive: шаг 12, изображение 3 из 3
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 13, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 13, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 13, изображение 3 из 3
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 14, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 14, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 14, изображение 3 из 3
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. iPad 6 Wi-Fi Microphone Assembly Replacement, Heat the right edge: шаг 15, изображение 1 из 1
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
  16. iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the top right adhesive: шаг 16, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the top right adhesive: шаг 16, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the top right adhesive: шаг 16, изображение 3 из 3
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
  17. iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the right adhesive: шаг 17, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the right adhesive: шаг 17, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the right adhesive: шаг 17, изображение 3 из 3
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
  18. iPad 6 Wi-Fi Microphone Assembly Replacement, Heat the bottom edge: шаг 18, изображение 1 из 1
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
  19. iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the bottom left adhesive: шаг 19, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the bottom left adhesive: шаг 19, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the bottom left adhesive: шаг 19, изображение 3 из 3
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the bottom-left corner before moving to the next step.
  20. iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the bottom adhesive: шаг 20, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the bottom adhesive: шаг 20, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the bottom adhesive: шаг 20, изображение 3 из 3
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 21, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 21, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 21, изображение 3 из 3
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
  22. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 22, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 22, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 22, изображение 3 из 3
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. iPad 6 Wi-Fi Microphone Assembly Replacement, Heat the right edge: шаг 23, изображение 1 из 1
  24. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 24, изображение 1 из 2 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 24, изображение 2 из 2
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 25, изображение 1 из 2 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 25, изображение 2 из 2
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  26. iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the right adhesive: шаг 26, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the right adhesive: шаг 26, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Separate the right adhesive: шаг 26, изображение 3 из 3
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
  27. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 27, изображение 1 из 2 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 27, изображение 2 из 2
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
  28. iPad 6 Wi-Fi Microphone Assembly Replacement, LCD: шаг 28, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, LCD: шаг 28, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, LCD: шаг 28, изображение 3 из 3
    • Remove any tape obscuring the LCD screws.
  29. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 29, изображение 1 из 1
    • Remove the four Phillips #00 4.3 mm screws securing the LCD.
  30. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 30, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 30, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 30, изображение 3 из 3
    • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers. There may be glue around the screw holes that needs to be cut with a knife.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Be gentle and keep an eye on the LCD cables as you flip the display over.
    • Lay the LCD on its face to allow access to the display cables.
    • Set the LCD down on a soft, clean, lint-free surface.
  31. iPad 6 Wi-Fi Microphone Assembly Replacement, Battery connector information: шаг 31, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Battery connector information: шаг 31, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Battery connector information: шаг 31, изображение 3 из 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  32. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 32, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 32, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 32, изображение 3 из 3
    • Remove the single 2.3 mm Phillips #000 screw securing the battery connector to the logic board.
    • To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery.
    • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at a 15 degree angle.
    • Leave the battery blocker in place as you work.
  33. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 33, изображение 1 из 1
    • Remove the three 1.4 mm Phillips #000 screws from the display cable bracket.
  34. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 34, изображение 1 из 2 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 34, изображение 2 из 2
    • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
    • The display cable connector is adhered to the underside of the bracket, so don’t push the spudger too far under the bracket, or you may damage the connector.
  35. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 35, изображение 1 из 1
    • Remove the LCD.
  36. iPad 6 Wi-Fi Microphone Assembly Replacement, Front Panel Assembly: шаг 36, изображение 1 из 2 iPad 6 Wi-Fi Microphone Assembly Replacement, Front Panel Assembly: шаг 36, изображение 2 из 2
    • Remove any tape covering the home button ribbon cable connector.
  37. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 37, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 37, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 37, изображение 3 из 3
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable straight out of the ZIF connector.
  38. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 38, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 38, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 38, изображение 3 из 3
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
    • During reassembly, make sure that these connectors are completely seated in their sockets, or you may encounter display issues.
  39. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 39, изображение 1 из 2 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 39, изображение 2 из 2
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
  40. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 40, изображение 1 из 2 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 40, изображение 2 из 2
    Polyimide Tape
    $9.99
    • Remove the front panel assembly.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  41. iPad 6 Wi-Fi Microphone Assembly Replacement, Upper Component Cable Bracket: шаг 41, изображение 1 из 1
    • Remove the three 1.4 mm Phillips #000 screws securing the upper component cable bracket.
  42. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 42, изображение 1 из 1
    • Remove the upper component cable bracket.
    • If you have the Wi-Fi/Cellular model, your iPad will look slightly different and will require the removal of two additional screws to access components covered by this bracket.
  43. iPad 6 Wi-Fi Microphone Assembly Replacement, Front Facing Camera: шаг 43, изображение 1 из 2 iPad 6 Wi-Fi Microphone Assembly Replacement, Front Facing Camera: шаг 43, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the front-facing camera connector from the logic board.
    • Only pry up on the connector—not on the socket itself.
  44. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 44, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 44, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 44, изображение 3 из 3
    • Use a spudger to pry the front-facing camera housing up and lift it out of the case.
    • Depending on how you performed the digitizer removal, this component may be adhered to the inner side of the front panel.
  45. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 45, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 45, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 45, изображение 3 из 3
    • Slide a spudger under the front-facing camera to separate it form the adhesive securing it to the rear case.
    • There is conductive tape between the front camera ribbon cable and the headphone jack cable underneath. When replacing your front camera, apply pressure on the gold contacts to readhere these cables.
    • Remove the front-facing camera from the iPad.
  46. iPad 6 Wi-Fi Microphone Assembly Replacement, Microphone: шаг 46, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Microphone: шаг 46, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement, Microphone: шаг 46, изображение 3 из 3
    • Use the flat end of a spudger to disconnect the headphone jack connector from the logic board.
    • Fold the headphone jack cable out of the way.
  47. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 47, изображение 1 из 2 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 47, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the microphone cable connector from the logic board.
  48. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 48, изображение 1 из 1
    • Place the top portion of the iPad on a reheated iOpener.
    • This will soften the adhesive holding the microphone assembly to the case.
  49. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 49, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 49, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 49, изображение 3 из 3
    • Insert the flat end of a spudger between the case and the microphone cable.
    • Carefully scrape the lower portion of the microphone cable off of the case.
  50. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 50, изображение 1 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 50, изображение 2 из 3 iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 50, изображение 3 из 3
    • Use the point of a spudger to pry the delicate upper portion of the microphone cable up off of the adhesive holding it to the rear case.
  51. iPad 6 Wi-Fi Microphone Assembly Replacement: шаг 51, изображение 1 из 1
    • Remove the dual microphone assembly from the iPad.
Заключение
3 человек успешно провели ремонт по этому руководству.
Arthur Shi
Участник с: 01/03/18
310 090 Репутация
Автор 701 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 23 638 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 30
За всё время: 2,388
