iPad Pro 12.9" 5th Gen Logic Board Replacement
Выберете то, что вам нужно
  1. iPad Pro 12.9" 5th Gen Logic Board Replacement, Prepare your iPad for disassembly: шаг 1, изображение 1 из 1
    • Allow your iPad's battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged during the repair.
    • If your battery is swollen, take appropriate precautions.
    • Unplug any cables and fully shut down your iPad.
  2. iPad Pro 12.9" 5th Gen Logic Board Replacement, Heat the right edge: шаг 2, изображение 1 из 1
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the iPad—the screen and internal battery are susceptible to heat damage.
  3. iPad Pro 12.9" 5th Gen Logic Board Replacement, Anti-Clamp instructions: шаг 3, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Anti-Clamp instructions: шаг 3, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Anti-Clamp instructions: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Anti-Clamp
    $24.95
    Купить
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 4, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 4, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 4, изображение 3 из 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 5, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 5, изображение 2 из 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad Pro 12.9" 5th Gen Logic Board Replacement, Insert an opening pick: шаг 6, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Insert an opening pick: шаг 6, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Insert an opening pick: шаг 6, изображение 3 из 3
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken display.
    • Apply a suction handle to the screen as close to the center of the right edge as possible.
    • Pull up on the suction handle with a strong, steady force to create a small gap between the frame and screen.
    • The large screen is very fragile. Only create a gap big enough to insert an opening pick.
    • If you're having trouble making a gap, reapply a heated iOpener to the right edge for two minutes.
    • Insert an opening pick into the gap.
    • Don't insert the pick more than 5 mm to avoid damaging the screen.
  7. iPad Pro 12.9" 5th Gen Logic Board Replacement, Right edge information: шаг 7, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Right edge information: шаг 7, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Right edge information: шаг 7, изображение 3 из 3
    • There are two 2 cm-long magnets along the right edge of the screen. Don't insert your opening pick more than 2 mm to avoid damaging the screen in these locations:
    • The first magnet begins about 3 cm from the top of the iPad.
    • The second magnet begins about 3 cm from the bottom of the iPad.
    • Everywhere else, don't insert your opening pick more than 5 mm.
  8. iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the right adhesive: шаг 8, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the right adhesive: шаг 8, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the right adhesive: шаг 8, изображение 3 из 3
    • Slide your opening pick along the right edge of the screen to separate the adhesive.
    • Angle your pick downward and insert up to a 2 mm depth near the magnet cutouts and 5 mm everywhere else.
    • Leave the pick inserted in the bottom right corner before continuing.
  9. iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the corner adhesive: шаг 9, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the corner adhesive: шаг 9, изображение 2 из 2
    • Slide your opening pick around the bottom right corner of the screen to separate the adhesive.
    • Leave your pick in the bottom right corner to prevent the adhesive from resealing.
  10. iPad Pro 12.9" 5th Gen Logic Board Replacement, Heat the bottom edge: шаг 10, изображение 1 из 1
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
  11. iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the bottom adhesive: шаг 11, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the bottom adhesive: шаг 11, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the bottom adhesive: шаг 11, изображение 3 из 3
    • Insert a second opening pick under the bottom right corner of the screen.
    • Don't insert your opening pick more than 5 mm.
    • Slide your pick to the bottom left corner to separate the bottom adhesive.
  12. iPad Pro 12.9" 5th Gen Logic Board Replacement, Slice the corner adhesive: шаг 12, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Slice the corner adhesive: шаг 12, изображение 2 из 2
    • Rotate your opening pick around the bottom left corner of the screen.
    • Leave your pick in the bottom left corner to prevent the adhesive from resealing.
  13. iPad Pro 12.9" 5th Gen Logic Board Replacement, Heat the left edge: шаг 13, изображение 1 из 1
    • Apply a heated iOpener to the left edge of the screen for two minutes.
  14. iPad Pro 12.9" 5th Gen Logic Board Replacement, Left edge information: шаг 14, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Left edge information: шаг 14, изображение 2 из 2
    • There are four 2 cm-long cutouts along the left edge of the screen where the adhesive is very thin. Don’t insert your opening pick more than 2 mm in these locations to avoid damaging the display:
    • The upper cutouts begin at 4 cm and 6 cm from the top of the frame.
    • The bottom cutouts begin at 4 cm and 6 cm from the bottom of the frame.
  15. iPad Pro 12.9" 5th Gen Logic Board Replacement, Slice the left adhesive: шаг 15, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Slice the left adhesive: шаг 15, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Slice the left adhesive: шаг 15, изображение 3 из 3
    • Insert a third opening pick under the bottom left corner of the screen.
    • Slide your pick to the top left corner to slice the left adhesive, making sure to avoid the cutouts shown in the previous step.
    • Leave the pick inserted in the top left corner before continuing.
  16. iPad Pro 12.9" 5th Gen Logic Board Replacement, Slice the corner adhesive: шаг 16, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Slice the corner adhesive: шаг 16, изображение 2 из 2
    • Slide your opening pick around the top left corner of the screen.
    • Leave your pick in the top left corner to prevent the adhesive from resealing.
  17. iPad Pro 12.9" 5th Gen Logic Board Replacement, Heat the top edge: шаг 17, изображение 1 из 1
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  18. iPad Pro 12.9" 5th Gen Logic Board Replacement, Top edge information: шаг 18, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Top edge information: шаг 18, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Top edge information: шаг 18, изображение 3 из 3
    • While the top edge adhesive softens, note the following:
    • There are two ambient light sensors near the corners. Don't insert your pick more than 1 mm here.
    • The front-facing camera and additional sensors are in the center of the top edge. Don't insert your pick here—there is less than 1 mm of adhesive and you may damage the components.
    • For everywhere else, don't insert your pick more than 5 mm to avoid damaging the screen.
  19. iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the top adhesive: шаг 19, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the top adhesive: шаг 19, изображение 2 из 2
    • Slide your opening pick toward the top right edge, stopping just before the camera assembly.
    • If you slide any farther, you risk damaging the camera's sensors.
    • Leave your pick inserted before continuing.
  20. iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 20, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 20, изображение 2 из 2
    • Insert a new opening pick on the other side of the camera assembly, about 4 cm from the previous pick.
    • Slide your pick to the top right corner to slice the remaining adhesive.
  21. iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the screen: шаг 21, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the screen: шаг 21, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the screen: шаг 21, изображение 3 из 3
    • Don't fully remove the screen, as it's attached by several cables.
    • Grab two opposing corners of the screen and lift up to separate it from the frame.
    • If the screen feels stuck, slide your opening picks around the perimeter to separate any remaining adhesive. Pay attention to sensitive areas shown in previous steps.
    • Shift the screen towards the bottom right corner of the frame until the ribbon cable near the top edge is uncovered.
  22. iPad Pro 12.9" 5th Gen Logic Board Replacement, Unfasten the upper cable shield: шаг 22, изображение 1 из 1
    FixMat
    $36.95
    Купить
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a Phillips screwdriver to remove the two screws securing the upper cable shield:
    • One 1.8 mm-long screw
    • One 1.4 mm-long screw
    • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
  23. iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the upper cable shield: шаг 23, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the upper cable shield: шаг 23, изображение 2 из 2
    • Use tweezers or your fingers to grab and remove the upper cable shield.
  24. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the upper sensors: шаг 24, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the upper sensors: шаг 24, изображение 2 из 2
    • Use the tip of a spudger to pry up and disconnect the upper sensors press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  25. iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the screen: шаг 25, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the screen: шаг 25, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the screen: шаг 25, изображение 3 из 3
    • Grip the right edge of the screen and open it like a book.
    • Don't pull up on the screen—the screen cables are still attached.
    • Lay the screen down over the left edge of the iPad.
    • Be careful not to strain the screen cables.
  26. iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the logic board cover: шаг 26, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the logic board cover: шаг 26, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the logic board cover: шаг 26, изображение 3 из 3
    • The logic board cover is lightly adhered to the logic board.
    • Peel the cover off of the logic board to remove it.
  27. iPad Pro 12.9" 5th Gen Logic Board Replacement, Unfasten the battery connector: шаг 27, изображение 1 из 1
    • Use a Phillips screwdriver to remove the 1.7 mm-long screw securing the battery connector to the logic board.
  28. iPad Pro 12.9" 5th Gen Logic Board Replacement, Unfasten the display brackets: шаг 28, изображение 1 из 1
    • Use a Phillips screwdriver to remove the seven screws securing the top and bottom display brackets:
    • Four 1.1 mm-long screws
    • Two 2.0 mm-long screws
    • One 1.0 mm-long screw
  29. iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the display brackets: шаг 29, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the display brackets: шаг 29, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the display brackets: шаг 29, изображение 3 из 3
    • Use tweezers, or your fingers, to remove the top and bottom display brackets.
  30. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the bottom display cables: шаг 30, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the bottom display cables: шаг 30, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the bottom display cables: шаг 30, изображение 3 из 3
    • Use a spudger to pry up and disconnect the two bottom display cable press connectors.
  31. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the top display cables: шаг 31, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the top display cables: шаг 31, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the top display cables: шаг 31, изображение 3 из 3
    • Use a spudger to pry up and disconnect the two top display cable press connectors.
  32. iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the screen: шаг 32, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the screen: шаг 32, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the screen: шаг 32, изображение 3 из 3
    • Remove the screen.
  33. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the charging port: шаг 33, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the charging port: шаг 33, изображение 2 из 2
    • Use a spudger to pry up and disconnect the charging port cable press connector.
  34. iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the charging port adhesive: шаг 34, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the charging port adhesive: шаг 34, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the charging port adhesive: шаг 34, изображение 3 из 3
    • The charging port cable is lightly adhered to the logic board.
    • Insert an opening pick between the charging port cable and the logic board.
    • Slide the pick toward the charging port to separate the adhesive.
  35. iPad Pro 12.9" 5th Gen Logic Board Replacement, Unfasten the charging port: шаг 35, изображение 1 из 1
    • Use a Phillips screwdriver to remove the two 1.8 mm-long screws securing the charging port.
  36. iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the grounding clips: шаг 36, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the grounding clips: шаг 36, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the grounding clips: шаг 36, изображение 3 из 3
    • Use tweezers to remove the two small grounding clips next to the charging port.
  37. iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the charging port: шаг 37, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the charging port: шаг 37, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the charging port: шаг 37, изображение 3 из 3
    • Use your fingers to pull the charging port out of its slot in the frame.
    • Remove the charging port.
  38. iPad Pro 12.9" 5th Gen Logic Board Replacement, Unfasten the front camera bracket: шаг 38, изображение 1 из 1
    • Use a Phillips screwdriver to remove the three screws securing the front camera bracket to the logic board:
    • Two 1.1 mm-long screws
  39. iPad Pro 12.9" 5th Gen Logic Board Replacement, Heat the front camera bracket: шаг 39, изображение 1 из 1
    • The front camera bracket is adhered to the logic board.
    • Heat an iOpener and apply it to the front camera bracket for two minutes.
  40. iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the bracket adhesive: шаг 40, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the bracket adhesive: шаг 40, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the bracket adhesive: шаг 40, изображение 3 из 3
    • Insert an opening pick between the front camera bracket and the logic board.
    • Slide the pick toward the top of the iPad to separate the adhesive.
  41. iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the front camera bracket: шаг 41, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the front camera bracket: шаг 41, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the front camera bracket: шаг 41, изображение 3 из 3
    • Slide the front camera bracket toward the right edge of the iPad to release its metal clip.
    • Remove the front camera bracket.
    • During reassembly, make sure the metal clip is secured under the logic board before continuing.
  42. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the front camera: шаг 42, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the front camera: шаг 42, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the front camera: шаг 42, изображение 3 из 3
    • Use a spudger to pry up and disconnect the three front camera cable press connectors.
  43. iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 43, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 43, изображение 2 из 2
    • The left-most front camera cable is lightly adhered to the frame.
    • Use tweezers, or your fingers, to peel the left-most cable off of the logic board.
  44. iPad Pro 12.9" 5th Gen Logic Board Replacement, Unfasten the front camera: шаг 44, изображение 1 из 1
    • Use a T3 Torx screwdriver to remove the two 2.2 mm-long screws securing the front camera.
  45. iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the front camera: шаг 45, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the front camera: шаг 45, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the front camera: шаг 45, изображение 3 из 3
    • The front camera is strongly adhered to the frame with heat-resistant epoxy. Work slowly to avoid damaging surrounding components.
    • Insert a spudger underneath the front camera, between the middle and right cables.
    • Twist the spudger to separate the epoxy securing the front camera.
    • This may require significant force.
    • Remove the front camera.
    • During reassembly, use a spudger to scrape off any remaining epoxy before reinstalling the front camera.
  46. iPad Pro 12.9" 5th Gen Logic Board Replacement, Unfasten the rear camera bracket: шаг 46, изображение 1 из 1
    • Use a Phillips screwdriver to remove the five screws securing the rear camera bracket to the frame:
    • Two 1.2 mm-long screws
    • One 2.7 mm-long screw
    • One 2.6 mm-long screw
  47. iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the rear camera bracket: шаг 47, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the rear camera bracket: шаг 47, изображение 2 из 2
    • Use tweezers, or your fingers, to remove the rear camera bracket.
  48. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the rear cameras: шаг 48, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the rear cameras: шаг 48, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the rear cameras: шаг 48, изображение 3 из 3
    • Use a spudger to pry up and disconnect the wide-angle camera cable press connector.
    • Disconnect the bottom power button cable press connector.
  49. iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 49, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 49, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 49, изображение 3 из 3
    • Use a spudger to pry up and disconnect the LiDAR sensor cable press connector.
    • Disconnect the ultrawide camera cable press connector.
  50. iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 50, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 50, изображение 2 из 2
    • Use a spudger to pry up and disconnect the top power button cable press connector.
  51. iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the rear camera assembly: шаг 51, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the rear camera assembly: шаг 51, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the rear camera assembly: шаг 51, изображение 3 из 3
    • Insert a spudger between the right edge of the rear camera assembly and the frame.
    • Pry up to separate the rear camera from the frame.
    • Remove the rear camera assembly.
  52. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the coaxial cables: шаг 52, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the coaxial cables: шаг 52, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the coaxial cables: шаг 52, изображение 3 из 3
    • Use the pointed end of a spudger to disconnect the six coaxial cables near the top of the iPad by prying up as close to their connectors as possible.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  53. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the top microphones: шаг 53, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the top microphones: шаг 53, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the top microphones: шаг 53, изображение 3 из 3
    • Use a spudger to pry up and disconnect the two top microphone press connectors.
  54. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the top speakers: шаг 54, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the top speakers: шаг 54, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the top speakers: шаг 54, изображение 3 из 3
    • Use the tip of a spudger to pry up and disconnect the four top speaker connectors.
    • Insert the spudger under the middle of the connectors. Alternatively, you can pry under the cables.
  55. iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the speaker cables: шаг 55, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the speaker cables: шаг 55, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the speaker cables: шаг 55, изображение 3 из 3
    • Three of the speaker cables are lightly adhered to the logic board.
    • Use tweezers, or your fingers, to peel the three speaker cables off of the logic board.
    • Grip the cables by the black foam tubes, not the wires themselves.
  56. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the 5G mmWave antenna: шаг 56, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the 5G mmWave antenna: шаг 56, изображение 2 из 2
    • Use a spudger to pry up and disconnect the 5G mmWave antenna press connector.
  57. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the top right microphone: шаг 57, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the top right microphone: шаг 57, изображение 2 из 2
    • Use a spudger to pry up and disconnect the top right microphone press connector.
  58. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the bottom speakers: шаг 58, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the bottom speakers: шаг 58, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the bottom speakers: шаг 58, изображение 3 из 3
    • Use the tip of a spudger to pry up and disconnect the four bottom speaker connectors.
  59. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the Smart Connector: шаг 59, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the Smart Connector: шаг 59, изображение 2 из 2
    • Use a spudger to pry up and disconnect the Smart Connector press connector.
  60. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the SIM card reader: шаг 60, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the SIM card reader: шаг 60, изображение 2 из 2
    • Use a spudger to pry up and disconnect the SIM card reader press connector.
  61. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the top antenna: шаг 61, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the top antenna: шаг 61, изображение 2 из 2
    • Use a spudger to pry up and disconnect the top antenna press connector.
  62. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the Wi-Fi antenna: шаг 62, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the Wi-Fi antenna: шаг 62, изображение 2 из 2
    • Use the pointed end of a spudger to disconnect the Wi-Fi antenna coaxial cable by prying up as close to its connector as possible.
  63. iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the Wi-Fi cable: шаг 63, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the Wi-Fi cable: шаг 63, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the Wi-Fi cable: шаг 63, изображение 3 из 3
    • Peel the Wi-Fi cable towards the right edge of the iPad to separate it from the logic board.
  64. iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the antenna cable: шаг 64, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the antenna cable: шаг 64, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the antenna cable: шаг 64, изображение 3 из 3
    • Begin to peel the antenna cable along the right edge of the logic board.
  65. iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 65, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 65, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 65, изображение 3 из 3
    • Continue peeling the antenna cable until it completely separates from the right edge of the logic board.
  66. iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the 5G mmWave antenna: шаг 66, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the 5G mmWave antenna: шаг 66, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Reposition the 5G mmWave antenna: шаг 66, изображение 3 из 3
    • Peel the 5G mmWave cable toward the right edge of the iPad to separate it from the logic board.
  67. iPad Pro 12.9" 5th Gen Logic Board Replacement, Unfasten the logic board brackets: шаг 67, изображение 1 из 1
    • Use a Phillips screwdriver to remove the two screws securing the logic board brackets:
    • One 1.1 mm-long screw
  68. iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the logic board brackets: шаг 68, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the logic board brackets: шаг 68, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the logic board brackets: шаг 68, изображение 3 из 3
    • Slide the right bracket away from the logic board to release its metal locking clip.
    • Remove the right bracket.
    • During reassembly, make sure the metal clips are secured under the logic board before continuing.
  69. iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 69, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 69, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 69, изображение 3 из 3
    • Slide the left bracket away from the logic board to release its metal locking clip.
    • Remove the left bracket.
  70. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the antenna: шаг 70, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the antenna: шаг 70, изображение 2 из 2
    • Use a spudger to pry up and disconnect the bottom left antenna press connector.
  71. iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the Apple Pencil charger: шаг 71, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the Apple Pencil charger: шаг 71, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Disconnect the Apple Pencil charger: шаг 71, изображение 3 из 3
    • Use a spudger to pry up and disconnect the left microphone and Apple Pencil charger cable press connectors.
  72. iPad Pro 12.9" 5th Gen Logic Board Replacement, Apply isopropyl alcohol: шаг 72, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Apply isopropyl alcohol: шаг 72, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Apply isopropyl alcohol: шаг 72, изображение 3 из 3
    • Apply high concentration (over 90%) isopropyl alcohol to the right edge of the logic board.
    • Tilt the right edge of the iPad upward to allow the isopropyl alcohol to work its way underneath the logic board.
    • Hold for one minute to allow the isopropyl alcohol to weaken the adhesive.
  73. iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the bottom adhesive: шаг 73, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the bottom adhesive: шаг 73, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the bottom adhesive: шаг 73, изображение 3 из 3
    • Slide an opening pick under the bottom edge of the logic board, near the charging port, to separate the bottom adhesive.
    • Leave the opening pick inserted to prevent the adhesive from resealing.
  74. iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the right adhesive: шаг 74, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the right adhesive: шаг 74, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the right adhesive: шаг 74, изображение 3 из 3
    • Insert an opening pick under the right edge of the logic board.
    • Slide the opening pick toward the battery connector to separate the right adhesive.
    • Leave the opening pick inserted next to the battery connector to prevent the adhesive from resealing.
  75. iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 75, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 75, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement: шаг 75, изображение 3 из 3
    • Insert a third opening pick under the logic board on the other side of the battery connector.
    • Slide the opening pick toward the top of the iPad to separate the remaining right adhesive.
  76. iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the left adhesive: шаг 76, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the left adhesive: шаг 76, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the left adhesive: шаг 76, изображение 3 из 3
    • Insert an opening pick under the left edge of the logic board.
    • Slide the opening pick along the left edge to separate its adhesive.
  77. iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the top adhesive: шаг 77, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the top adhesive: шаг 77, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the top adhesive: шаг 77, изображение 3 из 3
    • Slide a fifth opening pick under the top edge of the logic board, near the front camera, to separate the top adhesive.
  78. iPad Pro 12.9" 5th Gen Logic Board Replacement, Apply isopropyl alcohol: шаг 78, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Apply isopropyl alcohol: шаг 78, изображение 2 из 2
    • The logic board has a small "branch" that runs along the top right battery cell.
    • Apply high concentration (over 90%) isopropyl alcohol to the branch of the logic board.
  79. iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the remaining adhesive: шаг 79, изображение 1 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the remaining adhesive: шаг 79, изображение 2 из 3 iPad Pro 12.9" 5th Gen Logic Board Replacement, Separate the remaining adhesive: шаг 79, изображение 3 из 3
    • Slide the top right opening pick along the top branch of the logic board to separate the remaining adhesive.
    • At this point, the logic board should be fully separated from the frame. If the logic board still feels stuck, slide an opening pick around its perimeter to slice any remaining adhesive.
  80. iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the logic board: шаг 80, изображение 1 из 2 iPad Pro 12.9" 5th Gen Logic Board Replacement, Remove the logic board: шаг 80, изображение 2 из 2
    • Remove the logic board.
    • During reassembly, make sure all of the connectors are above the logic board before securing it back into the fame.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 12.9" 5th Generation Answers community for help.
Еще один человек закончил это руководство.
Alex Diaz-Kokaisl
Участник с: 01/16/22
124 236 Репутация
Автор 581 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 17 199 руководств
Один комментарий
Step 44 says to use a Phillips screwdriver to remove the two 2.2 mm-long screws securing the front camera. I'm working on a 6th gen and those screws are T3. In fact the pictures on step 44 look like Torx as well.
rcr6264 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 23
За последние 30 дней: 134
За всё время: 2,045
