iPhone 13 mini Bottom Speaker Replacement
Выберете то, что вам нужно
  1. iPhone 13 mini Bottom Speaker Replacement, Remove the screws: шаг 1, изображение 1 из 2 iPhone 13 mini Bottom Speaker Replacement, Remove the screws: шаг 1, изображение 2 из 2
    • For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 13 mini Bottom Speaker Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 13 mini Bottom Speaker Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 13 mini Bottom Speaker Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 13 mini Bottom Speaker Replacement, Tape over any cracks: шаг 3, изображение 1 из 3 iPhone 13 mini Bottom Speaker Replacement, Tape over any cracks: шаг 3, изображение 2 из 3 iPhone 13 mini Bottom Speaker Replacement, Tape over any cracks: шаг 3, изображение 3 из 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screenuntil the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 13 mini Bottom Speaker Replacement, Anti-Clamp instructions: шаг 4, изображение 1 из 3 iPhone 13 mini Bottom Speaker Replacement, Anti-Clamp instructions: шаг 4, изображение 2 из 3 iPhone 13 mini Bottom Speaker Replacement, Anti-Clamp instructions: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 13 mini Bottom Speaker Replacement: шаг 5, изображение 1 из 3 iPhone 13 mini Bottom Speaker Replacement: шаг 5, изображение 2 из 3 iPhone 13 mini Bottom Speaker Replacement: шаг 5, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 13 mini Bottom Speaker Replacement: шаг 6, изображение 1 из 3 iPhone 13 mini Bottom Speaker Replacement: шаг 6, изображение 2 из 3 iPhone 13 mini Bottom Speaker Replacement: шаг 6, изображение 3 из 3
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 13 mini Bottom Speaker Replacement, Heat the bottom edge: шаг 7, изображение 1 из 1
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  8. iPhone 13 mini Bottom Speaker Replacement, Apply a suction handle: шаг 8, изображение 1 из 1
    • If you're using a single suction handle, apply it to the bottom edge of the phone, as close to the edge as possible.
  9. iPhone 13 mini Bottom Speaker Replacement, Insert an opening pick: шаг 9, изображение 1 из 3 iPhone 13 mini Bottom Speaker Replacement, Insert an opening pick: шаг 9, изображение 2 из 3 iPhone 13 mini Bottom Speaker Replacement, Insert an opening pick: шаг 9, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone 13 mini Bottom Speaker Replacement, Heat the right edge: шаг 10, изображение 1 из 2 iPhone 13 mini Bottom Speaker Replacement, Heat the right edge: шаг 10, изображение 2 из 2
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  11. iPhone 13 mini Bottom Speaker Replacement, Separate the right adhesive: шаг 11, изображение 1 из 3 iPhone 13 mini Bottom Speaker Replacement, Separate the right adhesive: шаг 11, изображение 2 из 3 iPhone 13 mini Bottom Speaker Replacement, Separate the right adhesive: шаг 11, изображение 3 из 3
    • Slide the opening pick around the bottom right corner and along the right edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, and don't force it through unheated sections of adhesive, or it may slip and damage internal components.
    • Leave the pick in the top right corner before continuing.
  12. iPhone 13 mini Bottom Speaker Replacement, Heat the top edge: шаг 12, изображение 1 из 1
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  13. iPhone 13 mini Bottom Speaker Replacement, Separate the top adhesive: шаг 13, изображение 1 из 3 iPhone 13 mini Bottom Speaker Replacement, Separate the top adhesive: шаг 13, изображение 2 из 3 iPhone 13 mini Bottom Speaker Replacement, Separate the top adhesive: шаг 13, изображение 3 из 3
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
    • Leave the pick in the top left corner before continuing.
  14. iPhone 13 mini Bottom Speaker Replacement, Heat the left edge: шаг 14, изображение 1 из 2 iPhone 13 mini Bottom Speaker Replacement, Heat the left edge: шаг 14, изображение 2 из 2
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  15. iPhone 13 mini Bottom Speaker Replacement, Screen information: шаг 15, изображение 1 из 1
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  16. iPhone 13 mini Bottom Speaker Replacement, Separate the left adhesive: шаг 16, изображение 1 из 2 iPhone 13 mini Bottom Speaker Replacement, Separate the left adhesive: шаг 16, изображение 2 из 2
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
  17. iPhone 13 mini Bottom Speaker Replacement, Remove the suction cup(s): шаг 17, изображение 1 из 1
    • Pull on the small nub on the suction cup to remove it from the front panel.
  18. iPhone 13 mini Bottom Speaker Replacement, Open the iPhone mini: шаг 18, изображение 1 из 2 iPhone 13 mini Bottom Speaker Replacement, Open the iPhone mini: шаг 18, изображение 2 из 2
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  19. iPhone 13 mini Bottom Speaker Replacement, Unscrew the battery and display connector cover: шаг 19, изображение 1 из 1
    Magnetic Project Mat
    $19.95
    • Remove the 1.2 mm-long Y000 screw securing the battery and display connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  20. iPhone 13 mini Bottom Speaker Replacement, Remove the cover: шаг 20, изображение 1 из 2 iPhone 13 mini Bottom Speaker Replacement, Remove the cover: шаг 20, изображение 2 из 2
    • Use a pair of tweezers to remove the battery and display connector cover.
  21. iPhone 13 mini Bottom Speaker Replacement, Disconnect the battery and the OLED display cable: шаг 21, изображение 1 из 3 iPhone 13 mini Bottom Speaker Replacement, Disconnect the battery and the OLED display cable: шаг 21, изображение 2 из 3 iPhone 13 mini Bottom Speaker Replacement, Disconnect the battery and the OLED display cable: шаг 21, изображение 3 из 3
    • Use a spudger to pry the battery and OLED panel cable connectors up from their sockets on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  22. iPhone 13 mini Bottom Speaker Replacement, Unscrew the front sensor connector cover: шаг 22, изображение 1 из 1
    • Remove the three screws (securing the front sensor assembly cover):
    • One PH000 1.4 mm-long screw
    • One Y000 1.8 mm-long screw
    • One Y000 1.2 mm-long screw
  23. iPhone 13 mini Bottom Speaker Replacement, Remove the cover: шаг 23, изображение 1 из 2 iPhone 13 mini Bottom Speaker Replacement, Remove the cover: шаг 23, изображение 2 из 2
    • Use a pair of tweezers to remove the front sensor assembly connector cover.
  24. iPhone 13 mini Bottom Speaker Replacement, Disconnect the front sensors: шаг 24, изображение 1 из 2 iPhone 13 mini Bottom Speaker Replacement, Disconnect the front sensors: шаг 24, изображение 2 из 2
    • Use a spudger to disconnect the front sensor assembly cable connector.
  25. iPhone 13 mini Bottom Speaker Replacement, Remove the display assembly: шаг 25, изображение 1 из 1
  26. iPhone 13 mini Bottom Speaker Replacement, Unscrew the speaker: шаг 26, изображение 1 из 1
    • Remove the four 1.5 mm-long Phillips screws securing the speaker.
  27. iPhone 13 mini Bottom Speaker Replacement, Remove the speaker: шаг 27, изображение 1 из 2 iPhone 13 mini Bottom Speaker Replacement, Remove the speaker: шаг 27, изображение 2 из 2
    • Use a pair of tweezers to remove the speaker.
Заключение
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 13 mini Answers community for help.
Еще один человек закончил это руководство.
Adriana Zwink
Участник с: 12/18/19
56 077 Репутация
Автор 167 руководств
Команду
iFixit Участник iFixit
Staff
118 членов
Автор 19 410 руководств
Один комментарий
Hi, why do I need to disassemble the screen and other mentioned cables? Why can’t I just open the iPhone’s screen to a 90 degrees angle - like a book (and lean it on something, with everything still connected), and just go to step 26 - the disassembly of the 4 speaker screws? Is there really a need to disassemble completely the screen and other cables?
David - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 24
За последние 7 дней: 94
За последние 30 дней: 398
За всё время: 11,470
