iPhone 15 Pro Max Front Camera Assembly Replacement
Выберете то, что вам нужно
  1. iPhone 15 Pro Max Front Camera Assembly Replacement, Prepare your phone for disassembly: шаг 1, изображение 1 из 2 iPhone 15 Pro Max Front Camera Assembly Replacement, Prepare your phone for disassembly: шаг 1, изображение 2 из 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Pro Max Front Camera Assembly Replacement, Tape over any cracks: шаг 2, изображение 1 из 2 iPhone 15 Pro Max Front Camera Assembly Replacement, Tape over any cracks: шаг 2, изображение 2 из 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Pro Max Front Camera Assembly Replacement, Mark your opening picks: шаг 3, изображение 1 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Mark your opening picks: шаг 3, изображение 2 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Mark your opening picks: шаг 3, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the pentalobe screws: шаг 4, изображение 1 из 1
    • Use a P2 pentalobe driver to remove the two 7.2 mm-long screws on either side of the charging port.
  5. iPhone 15 Pro Max Front Camera Assembly Replacement, Secure the back glass: шаг 5, изображение 1 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Secure the back glass: шаг 5, изображение 2 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Secure the back glass: шаг 5, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next four steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down four steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • The Anti-Clamp applies suction to both the screen and the back glass. To open the screen, you need to secure the back glass with tape. You can also check out the full instructions on how to use this tape.
    • Cut two strips of tape, apply them along the long edges of the phone, and fold them over the back glass to secure it.
  6. iPhone 15 Pro Max Front Camera Assembly Replacement, Secure an Anti-Clamp: шаг 6, изображение 1 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Secure an Anti-Clamp: шаг 6, изображение 2 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Secure an Anti-Clamp: шаг 6, изображение 3 из 3
    • Pull the Anti-Clamp's blue handle backward to unlock the arms.
    • With the screen facing up, slide the arms over the left edge of your phone, with one suction cup on the screen and the other on the back glass. Center the suction cups near the bottom edge.
    • Support your phone so it rests level while between the Anti-Clamp's arms—a small box works well.
    • Squeeze the cups together to create suction.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  7. iPhone 15 Pro Max Front Camera Assembly Replacement, Create a gap under the screen: шаг 7, изображение 1 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Create a gap under the screen: шаг 7, изображение 2 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Create a gap under the screen: шаг 7, изображение 3 из 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle one full turn (360 degrees) or until the cups start to stretch.
    • As the cups stretch, make sure they stay vertically aligned with each other. If they tend to slip, remove the Anti-Clamp and apply tape for the cups to stick to.
    • If you don't have tape, you may use your hands to clean the suction cups and warm them up to help them stick.
  8. iPhone 15 Pro Max Front Camera Assembly Replacement, Insert an opening pick: шаг 8, изображение 1 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Insert an opening pick: шаг 8, изображение 2 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Insert an opening pick: шаг 8, изображение 3 из 3
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    • Wait up to a minute for the adhesive to separate and a gap to form between the screen and the frame.
    • If a gap doesn't appear after one minute, apply more heat and rotate the handle a quarter turn. Let the Anti-Clamp and time do the work for you.
    • Insert an opening pick into the gap.
    • Remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  9. iPhone 15 Pro Max Front Camera Assembly Replacement, Heat the bottom edge: шаг 9, изображение 1 из 1
  10. iPhone 15 Pro Max Front Camera Assembly Replacement, Insert an opening pick: шаг 10, изображение 1 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Insert an opening pick: шаг 10, изображение 2 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Insert an opening pick: шаг 10, изображение 3 из 3
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  11. iPhone 15 Pro Max Front Camera Assembly Replacement, Screen information: шаг 11, изображение 1 из 1
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
  12. iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the bottom edge adhesive: шаг 12, изображение 1 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the bottom edge adhesive: шаг 12, изображение 2 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the bottom edge adhesive: шаг 12, изображение 3 из 3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  13. iPhone 15 Pro Max Front Camera Assembly Replacement, Heat the right edge: шаг 13, изображение 1 из 1
    • Heat the right edge of the screen until it's hot to the touch.
  14. iPhone 15 Pro Max Front Camera Assembly Replacement, Position the opening pick: шаг 14, изображение 1 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Position the opening pick: шаг 14, изображение 2 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Position the opening pick: шаг 14, изображение 3 из 3
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
  15. iPhone 15 Pro Max Front Camera Assembly Replacement, Release the right clip: шаг 15, изображение 1 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Release the right clip: шаг 15, изображение 2 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Release the right clip: шаг 15, изображение 3 из 3
    • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
    • Insert a second opening pick to the right of the first pick.
  16. iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the right edge adhesive: шаг 16, изображение 1 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the right edge adhesive: шаг 16, изображение 2 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the right edge adhesive: шаг 16, изображение 3 из 3
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
  17. iPhone 15 Pro Max Front Camera Assembly Replacement, Heat the top edge: шаг 17, изображение 1 из 1
    • Heat the top edge of the screen until it's hot to the touch.
  18. iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the top edge adhesive: шаг 18, изображение 1 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the top edge adhesive: шаг 18, изображение 2 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the top edge adhesive: шаг 18, изображение 3 из 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
  19. iPhone 15 Pro Max Front Camera Assembly Replacement, Heat the left edge: шаг 19, изображение 1 из 1
    • Heat the left edge of the screen until it's hot to the touch.
  20. iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the left edge adhesive: шаг 20, изображение 1 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the left edge adhesive: шаг 20, изображение 2 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the left edge adhesive: шаг 20, изображение 3 из 3
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
  21. iPhone 15 Pro Max Front Camera Assembly Replacement, Swing open the screen: шаг 21, изображение 1 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Swing open the screen: шаг 21, изображение 2 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Swing open the screen: шаг 21, изображение 3 из 3
    • Gently swing open the screen to the left of the phone.
    • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the screen against a box or similar object so it doesn't strain the cables.
  22. iPhone 15 Pro Max Front Camera Assembly Replacement, Unfasten the logic board cover: шаг 22, изображение 1 из 2 iPhone 15 Pro Max Front Camera Assembly Replacement, Unfasten the logic board cover: шаг 22, изображение 2 из 2
    FixMat
    $36.95
    • Use a tri-point Y000 driver to remove the six screws securing the logic board cover:
    • One 2.1 mm‑long screw
    • Five 1.5 mm‑long screws
  23. iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the logic board cover: шаг 23, изображение 1 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the logic board cover: шаг 23, изображение 2 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the logic board cover: шаг 23, изображение 3 из 3
    • Use tweezers or your fingers to grab and slide the logic board cover toward the bottom of the phone to clear the sensor cable.
    • Remove the cover.
  24. iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the battery: шаг 24, изображение 1 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the battery: шаг 24, изображение 2 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the battery: шаг 24, изображение 3 из 3
    • Use the tip of an opening pick to pry up and disconnect the battery press connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
  25. iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the ambient light sensor: шаг 25, изображение 1 из 2 iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the ambient light sensor: шаг 25, изображение 2 из 2
    • Use the point of a spudger to pry up and disconnect the ambient light sensor press connector from the top left of the logic board.
  26. iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the screen: шаг 26, изображение 1 из 2 iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the screen: шаг 26, изображение 2 из 2
    • Disconnect the screen press connector.
  27. iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the screen: шаг 27, изображение 1 из 2 iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the screen: шаг 27, изображение 2 из 2
    • Remove the screen.
    • During reassembly, stop here and use this guide to install new screen adhesive.
    • Be careful not to damage any of the spring contacts as you clean the frame.
  28. iPhone 15 Pro Max Front Camera Assembly Replacement, Unfasten the earpiece speaker: шаг 28, изображение 1 из 1
    • Use a Phillips #000 driver to remove the two screws securing the earpiece speaker:
    • One 1.8 mm screw
    • One 2.4 mm screw
  29. iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the earpiece speaker: шаг 29, изображение 1 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the earpiece speaker: шаг 29, изображение 2 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the earpiece speaker: шаг 29, изображение 3 из 3
    • Insert the flat end of your spudger between the left edge of the earpiece speaker and the frame.
    • Pry up until you can grab the speaker with your fingers.
    • Remove the speaker.
    • During reassembly, insert the speaker at a downward angle so the gasket slides into its recess in the top edge of the frame.
  30. iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the front camera assembly: шаг 30, изображение 1 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the front camera assembly: шаг 30, изображение 2 из 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the front camera assembly: шаг 30, изображение 3 из 3
    • Use the tip of an opening pick to pry up and disconnect the microphone, front camera, and proximity sensor press connectors from the top of the logic board (three connectors in total).
  31. iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the front camera assembly: шаг 31, изображение 1 из 2 iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the front camera assembly: шаг 31, изображение 2 из 2
    • Use tweezers or your fingers to pull the front camera assembly out of its recess in the frame and remove it.
    • Be careful not to touch the camera or sensor lenses.
Заключение
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
3 человек успешно провели ремонт по этому руководству.
Clay Eickemeyer
Участник с: 09/19/22
82 264 Репутация
Автор 455 руководств
Команду
Guide Team Участник Guide Team
Staff
9 членов
Автор 11 491 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 9
За последние 7 дней: 99
За последние 30 дней: 620
За всё время: 5,625
