iPhone 15 Pro Screen Replacement
Выберете то, что вам нужно
  1. iPhone 15 Pro Screen Replacement, Prepare your iPhone for disassembly: шаг 1, изображение 1 из 2 iPhone 15 Pro Screen Replacement, Prepare your iPhone for disassembly: шаг 1, изображение 2 из 2
    • Let your phone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Hold the power and either volume button and slide to power off your phone.
  2. iPhone 15 Pro Screen Replacement, Tape over any cracks: шаг 2, изображение 1 из 2 iPhone 15 Pro Screen Replacement, Tape over any cracks: шаг 2, изображение 2 из 2
    • If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Pro Screen Replacement, Mark your opening picks: шаг 3, изображение 1 из 3 iPhone 15 Pro Screen Replacement, Mark your opening picks: шаг 3, изображение 2 из 3 iPhone 15 Pro Screen Replacement, Mark your opening picks: шаг 3, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  4. iPhone 15 Pro Screen Replacement, Remove the pentalobe screws: шаг 4, изображение 1 из 2 iPhone 15 Pro Screen Replacement, Remove the pentalobe screws: шаг 4, изображение 2 из 2
    • Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
  5. iPhone 15 Pro Screen Replacement, Heat the bottom edge: шаг 5, изображение 1 из 1
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 15 Pro Screen Replacement, Insert an opening pick: шаг 6, изображение 1 из 3 iPhone 15 Pro Screen Replacement, Insert an opening pick: шаг 6, изображение 2 из 3 iPhone 15 Pro Screen Replacement, Insert an opening pick: шаг 6, изображение 3 из 3
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Pro Screen Replacement, Screen information: шаг 7, изображение 1 из 1
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
  8. iPhone 15 Pro Screen Replacement, Separate the bottom edge adhesive: шаг 8, изображение 1 из 3 iPhone 15 Pro Screen Replacement, Separate the bottom edge adhesive: шаг 8, изображение 2 из 3 iPhone 15 Pro Screen Replacement, Separate the bottom edge adhesive: шаг 8, изображение 3 из 3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Pro Screen Replacement, Heat the right edge: шаг 9, изображение 1 из 1
    • Heat the right edge of the screen until it's hot to the touch.
  10. iPhone 15 Pro Screen Replacement, Position the opening pick: шаг 10, изображение 1 из 3 iPhone 15 Pro Screen Replacement, Position the opening pick: шаг 10, изображение 2 из 3 iPhone 15 Pro Screen Replacement, Position the opening pick: шаг 10, изображение 3 из 3
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
  11. iPhone 15 Pro Screen Replacement, Release the right clip: шаг 11, изображение 1 из 3 iPhone 15 Pro Screen Replacement, Release the right clip: шаг 11, изображение 2 из 3 iPhone 15 Pro Screen Replacement, Release the right clip: шаг 11, изображение 3 из 3
    • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
    • Insert a second opening pick to the right of the first pick.
  12. iPhone 15 Pro Screen Replacement, Separate the right edge adhesive: шаг 12, изображение 1 из 3 iPhone 15 Pro Screen Replacement, Separate the right edge adhesive: шаг 12, изображение 2 из 3 iPhone 15 Pro Screen Replacement, Separate the right edge adhesive: шаг 12, изображение 3 из 3
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
  13. iPhone 15 Pro Screen Replacement, Heat the top edge: шаг 13, изображение 1 из 1
    • Heat the top edge of the screen until it's hot to the touch.
  14. iPhone 15 Pro Screen Replacement, Separate the top edge adhesive: шаг 14, изображение 1 из 3 iPhone 15 Pro Screen Replacement, Separate the top edge adhesive: шаг 14, изображение 2 из 3 iPhone 15 Pro Screen Replacement, Separate the top edge adhesive: шаг 14, изображение 3 из 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
  15. iPhone 15 Pro Screen Replacement, Heat the left edge: шаг 15, изображение 1 из 1
    • Heat the left edge of the screen until it's hot to the touch.
  16. iPhone 15 Pro Screen Replacement, Separate the left edge adhesive: шаг 16, изображение 1 из 3 iPhone 15 Pro Screen Replacement, Separate the left edge adhesive: шаг 16, изображение 2 из 3 iPhone 15 Pro Screen Replacement, Separate the left edge adhesive: шаг 16, изображение 3 из 3
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
  17. iPhone 15 Pro Screen Replacement, Prop up the screen: шаг 17, изображение 1 из 3 iPhone 15 Pro Screen Replacement, Prop up the screen: шаг 17, изображение 2 из 3 iPhone 15 Pro Screen Replacement, Prop up the screen: шаг 17, изображение 3 из 3
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cables.
    • Swing up the right edge of the screen like the front cover of a book.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access its cables without straining them.
  18. iPhone 15 Pro Screen Replacement, Unfasten the logic board cover: шаг 18, изображение 1 из 2 iPhone 15 Pro Screen Replacement, Unfasten the logic board cover: шаг 18, изображение 2 из 2
    • Use a Y000 screwdriver to remove the six screws securing the logic board cover:
    • Four 1.6 mm‑long screws
    • Two 1.3 mm‑long screws
  19. iPhone 15 Pro Screen Replacement, Remove the logic board cover: шаг 19, изображение 1 из 3 iPhone 15 Pro Screen Replacement, Remove the logic board cover: шаг 19, изображение 2 из 3 iPhone 15 Pro Screen Replacement, Remove the logic board cover: шаг 19, изображение 3 из 3
    • Rotate the bottom of the logic board cover counterclockwise and slide the top left corner out from under the ambient light sensor cable to remove it.
    • During reassembly, make sure the top left corner of the cover goes under the ambient light sensor cable.
  20. iPhone 15 Pro Screen Replacement, Disconnect the battery: шаг 20, изображение 1 из 3 iPhone 15 Pro Screen Replacement, Disconnect the battery: шаг 20, изображение 2 из 3 iPhone 15 Pro Screen Replacement, Disconnect the battery: шаг 20, изображение 3 из 3
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the bottom right corner of the logic board.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
  21. iPhone 15 Pro Screen Replacement, Disconnect the screen: шаг 21, изображение 1 из 2 iPhone 15 Pro Screen Replacement, Disconnect the screen: шаг 21, изображение 2 из 2
    • Use the tip of an opening pick to pry up and disconnect the screen cable from the center of the logic board.
  22. iPhone 15 Pro Screen Replacement, Disconnect the ambient light sensor: шаг 22, изображение 1 из 2 iPhone 15 Pro Screen Replacement, Disconnect the ambient light sensor: шаг 22, изображение 2 из 2
    • Gently slide the tip of an opening pick under the ambient light sensor cable near the top left corner of the logic board.
    • Lift the cable to disconnect it.
  23. iPhone 15 Pro Screen Replacement, Remove the screen: шаг 23, изображение 1 из 2 iPhone 15 Pro Screen Replacement, Remove the screen: шаг 23, изображение 2 из 2
    • Remove the screen.
    • During reassembly, follow this guide to apply new adhesive and install your screen.
    • Be careful not to damage any of the spring contacts as you clean the frame.
  24. iPhone 15 Pro Screen Replacement, Ambient light sensor information: шаг 24, изображение 1 из 2 iPhone 15 Pro Screen Replacement, Ambient light sensor information: шаг 24, изображение 2 из 2
    • Check if your new screen comes with an ambient light sensor installed.
    • If it doesn't, follow the remaining steps to remove and transfer the sensor from your original screen to your replacement.
  25. iPhone 15 Pro Screen Replacement, Remove the ambient light sensor cover screws: шаг 25, изображение 1 из 2 iPhone 15 Pro Screen Replacement, Remove the ambient light sensor cover screws: шаг 25, изображение 2 из 2
    • Use a Phillips #000 driver to remove the two screws securing the ambient light sensor cover.
  26. iPhone 15 Pro Screen Replacement, Remove the ambient light sensor cover: шаг 26, изображение 1 из 1
    • Remove the ambient light sensor cover.
  27. iPhone 15 Pro Screen Replacement, Heat the ambient light sensor adhesive: шаг 27, изображение 1 из 1
    • Be careful not to overheat the screen—the plastic components can melt if they get too hot.
    • Use a hair dryer or heat gun to heat the ambient light sensor until it's warm to the touch.
  28. iPhone 15 Pro Screen Replacement, Pry up the sensor: шаг 28, изображение 1 из 2 iPhone 15 Pro Screen Replacement, Pry up the sensor: шаг 28, изображение 2 из 2
    • Be very gentle handing the ambient light sensor, as its cable is extremely fragile.
    • use the flat end of a spudger to gently lift the ambient light sensor out of its enclosure.
  29. iPhone 15 Pro Screen Replacement, Reheat the ambient light sensor: шаг 29, изображение 1 из 1
    • By this point, the sensor has likely cooled down.
    • Apply more heat until the entire glued down part of the sensor is warm to the touch.
  30. iPhone 15 Pro Screen Replacement: шаг 30, изображение 1 из 3 iPhone 15 Pro Screen Replacement: шаг 30, изображение 2 из 3 iPhone 15 Pro Screen Replacement: шаг 30, изображение 3 из 3
    • Insert the tip of an opening pick under the bottom right corner of the sensor.
    • Slide the pick under the sensor and lift until you can grip it with your fingers.
  31. iPhone 15 Pro Screen Replacement, Remove the ambient light sensor: шаг 31, изображение 1 из 1
    • Use your fingers to slowly peel up and remove the sensor.
Заключение
To reassemble your iPhone, follow this guide to apply new adhesive and install your screen.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
27 человек успешно провели ремонт по этому руководству.
Spencer Day
Участник с: 09/14/22
160 117 Репутация
Автор 1 045 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 23 992 руководств
8 Комментарии к руководству
Pls also make the videos of your guides available on YouTube so it can be more understandable
Seyi Raji - Ответить
Where the hell do you buy the replacement display on the iFixIt website?
Anonymous - Ответить
You can buy it at selfservicerepair.com it is a lot cheaper there
nicholaswiding -
This adhesive is way more annoying than it has any logical reason to be.
Seth Blagg - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 121
За последние 7 дней: 1,062
За последние 30 дней: 4,974
За всё время: 75,809
