iPhone 6 Plus LCD and Digitizer Replacement
Выберете то, что вам нужно
Видеообзор
  1. iPhone 6 Plus LCD and Digitizer Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
  2. iPhone 6 Plus LCD and Digitizer Replacement, Taping Over The Display: шаг 2, изображение 1 из 3 iPhone 6 Plus LCD and Digitizer Replacement, Taping Over The Display: шаг 2, изображение 2 из 3 iPhone 6 Plus LCD and Digitizer Replacement, Taping Over The Display: шаг 2, изображение 3 из 3
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
  3. iPhone 6 Plus LCD and Digitizer Replacement, Anti-Clamp instructions: шаг 3, изображение 1 из 3 iPhone 6 Plus LCD and Digitizer Replacement, Anti-Clamp instructions: шаг 3, изображение 2 из 3 iPhone 6 Plus LCD and Digitizer Replacement, Anti-Clamp instructions: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 6 Plus LCD and Digitizer Replacement: шаг 4, изображение 1 из 3 iPhone 6 Plus LCD and Digitizer Replacement: шаг 4, изображение 2 из 3 iPhone 6 Plus LCD and Digitizer Replacement: шаг 4, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick or tool under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  5. iPhone 6 Plus LCD and Digitizer Replacement, Front Panel Assembly: шаг 5, изображение 1 из 1
    • Use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  6. iPhone 6 Plus LCD and Digitizer Replacement: шаг 6, изображение 1 из 1
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  7. iPhone 6 Plus LCD and Digitizer Replacement: шаг 7, изображение 1 из 2 iPhone 6 Plus LCD and Digitizer Replacement: шаг 7, изображение 2 из 2
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  8. iPhone 6 Plus LCD and Digitizer Replacement: шаг 8, изображение 1 из 3 iPhone 6 Plus LCD and Digitizer Replacement: шаг 8, изображение 2 из 3 iPhone 6 Plus LCD and Digitizer Replacement: шаг 8, изображение 3 из 3
    • Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  9. iPhone 6 Plus LCD and Digitizer Replacement: шаг 9, изображение 1 из 2 iPhone 6 Plus LCD and Digitizer Replacement: шаг 9, изображение 2 из 2
    • Several clips along the top edge of the front panel form a partial hinge, allowing the front panel assembly to swing open like a book.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  10. iPhone 6 Plus LCD and Digitizer Replacement: шаг 10, изображение 1 из 1
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.3 mm screw
    • One 3.1 mm screw
  11. iPhone 6 Plus LCD and Digitizer Replacement: шаг 11, изображение 1 из 1
    • Remove the metal battery connector bracket from the iPhone.
  12. iPhone 6 Plus LCD and Digitizer Replacement: шаг 12, изображение 1 из 1
    • Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  13. iPhone 6 Plus LCD and Digitizer Replacement: шаг 13, изображение 1 из 1
    • Remove the following Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.5 mm screw
    • One 2.9 mm screw
    • Do not attempt to insert longer screws into the red marked screw holes. Doing so may result in irreparable damage to the logic board.
  14. iPhone 6 Plus LCD and Digitizer Replacement: шаг 14, изображение 1 из 1
    • Remove the front panel assembly cable bracket from the logic board.
  15. iPhone 6 Plus LCD and Digitizer Replacement: шаг 15, изображение 1 из 2 iPhone 6 Plus LCD and Digitizer Replacement: шаг 15, изображение 2 из 2
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
  16. iPhone 6 Plus LCD and Digitizer Replacement: шаг 16, изображение 1 из 2 iPhone 6 Plus LCD and Digitizer Replacement: шаг 16, изображение 2 из 2
    • Disconnect the home button cable connector.
  17. iPhone 6 Plus LCD and Digitizer Replacement: шаг 17, изображение 1 из 2 iPhone 6 Plus LCD and Digitizer Replacement: шаг 17, изображение 2 из 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a plastic opening tool to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  18. iPhone 6 Plus LCD and Digitizer Replacement: шаг 18, изображение 1 из 2 iPhone 6 Plus LCD and Digitizer Replacement: шаг 18, изображение 2 из 2
    • Finally, disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  19. iPhone 6 Plus LCD and Digitizer Replacement: шаг 19, изображение 1 из 1
    • Remove the front panel assembly from the rear case.
  20. iPhone 6 Plus LCD and Digitizer Replacement, Earpiece Speaker: шаг 20, изображение 1 из 1
    • Remove the following Phillips screws securing the upper component bracket:
    • One 1.5 mm screw
    • Two 2.3 mm screws
  21. iPhone 6 Plus LCD and Digitizer Replacement: шаг 21, изображение 1 из 1
    • Lift and remove the earpiece bracket from the display assembly.
  22. iPhone 6 Plus LCD and Digitizer Replacement: шаг 22, изображение 1 из 1
    • Use a the flat end of a spudger to pry up the front-facing camera and display cables, and gently push them aside.
  23. iPhone 6 Plus LCD and Digitizer Replacement: шаг 23, изображение 1 из 1
    • Use a pair of tweezers to firmly grasp and remove the earpiece speaker from the display assembly.
  24. iPhone 6 Plus LCD and Digitizer Replacement, Front Facing Camera and Sensor Assembly: шаг 24, изображение 1 из 2 iPhone 6 Plus LCD and Digitizer Replacement, Front Facing Camera and Sensor Assembly: шаг 24, изображение 2 из 2
    • Use the tip of a spudger to gently pry up the sensor cable assembly from its recess in the display assembly.
    • The cable is held in place with a mild adhesive.
  25. iPhone 6 Plus LCD and Digitizer Replacement: шаг 25, изображение 1 из 2 iPhone 6 Plus LCD and Digitizer Replacement: шаг 25, изображение 2 из 2
    • Pry the microphone portion of the front-facing camera and sensor cables from the display assembly.
  26. iPhone 6 Plus LCD and Digitizer Replacement: шаг 26, изображение 1 из 1
    • Remove the front-facing camera and sensor cable assembly off the display assembly.
    • Replacement assemblies may or may not come with the speaker mesh already attached. If it's missing, save your old one and re-use it. You can separate it with some heat from a hair dryer and gentle prying or pulling with tweezers.
  27. iPhone 6 Plus LCD and Digitizer Replacement, Home Button Assembly: шаг 27, изображение 1 из 1
    • Remove the two 1.8 mm Phillips screws securing the home button bracket to the front panel.
  28. iPhone 6 Plus LCD and Digitizer Replacement: шаг 28, изображение 1 из 1
    • Remove the home button bracket from the front panel assembly.
  29. iPhone 6 Plus LCD and Digitizer Replacement: шаг 29, изображение 1 из 2 iPhone 6 Plus LCD and Digitizer Replacement: шаг 29, изображение 2 из 2
    • Use the tip of a spudger to disconnect the home button connector from its socket on the home button cable.
  30. iPhone 6 Plus LCD and Digitizer Replacement: шаг 30, изображение 1 из 1
    iOpener
    $14.99
    • Carefully wedge the tip of a spudger underneath the home button connector cable.
    • Gently move the spudger across to separate the home button connector cable from the adhesive securing it to the front panel assembly.
    • If the cable doesn't separate easily, apply heat using an iOpener or hair dryer to soften the adhesive, and try again. Be careful not to damage the cable.
  31. iPhone 6 Plus LCD and Digitizer Replacement: шаг 31, изображение 1 из 2 iPhone 6 Plus LCD and Digitizer Replacement: шаг 31, изображение 2 из 2
    iOpener
    $24.99
    • The rubber gasket surrounding the home button is very thin and tears easily.
    • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
    • Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
  32. iPhone 6 Plus LCD and Digitizer Replacement: шаг 32, изображение 1 из 2 iPhone 6 Plus LCD and Digitizer Replacement: шаг 32, изображение 2 из 2
    • Carefully use the tip of a spudger to finish separating the home button from the front panel.
  33. iPhone 6 Plus LCD and Digitizer Replacement: шаг 33, изображение 1 из 1
    • Lift and remove the home button assembly off the front panel assembly.
  34. iPhone 6 Plus LCD and Digitizer Replacement, LCD and Digitizer: шаг 34, изображение 1 из 2 iPhone 6 Plus LCD and Digitizer Replacement, LCD and Digitizer: шаг 34, изображение 2 из 2
    • Remove the two 1.7 mm Phillips screws (one on top and one on bottom) securing the LCD shield plate to the display assembly.
  35. iPhone 6 Plus LCD and Digitizer Replacement: шаг 35, изображение 1 из 2 iPhone 6 Plus LCD and Digitizer Replacement: шаг 35, изображение 2 из 2
    • Remove three 1.3 mm Phillips screws from each side of the LCD shield plate (six total).
  36. iPhone 6 Plus LCD and Digitizer Replacement: шаг 36, изображение 1 из 2 iPhone 6 Plus LCD and Digitizer Replacement: шаг 36, изображение 2 из 2
    • The next step requires peeling one end of the home button cable (highlighted in red in the second picture) that is affixed to the back of the display assembly with strong adhesive. We highly recommend using an iOpener to heat the bottom of the display assembly, directly on top of the home button.
  37. iPhone 6 Plus LCD and Digitizer Replacement: шаг 37, изображение 1 из 3 iPhone 6 Plus LCD and Digitizer Replacement: шаг 37, изображение 2 из 3 iPhone 6 Plus LCD and Digitizer Replacement: шаг 37, изображение 3 из 3
    • Carefully lift—but do not remove—the LCD shield plate by lifting the end nearest the earpiece speaker a few millimeters from the display assembly.
    • Gently lift the other end (nearest the home button) to peel the home button cable off the display assembly.
    • Be extremely cautious as you peel the home button cable. It is a fragile cable. If you feel more than slight resistance, we recommend reheating and reusing the iOpener to soften the adhesive.
    • Remove the LCD shield plate off the display assembly.
    • Display assembly remains.
Заключение
222 человек успешно провели ремонт по этому руководству.
11 Комментарии к руководству
I know this is a old guide but i have a question. My iphone was screen broken and i change it with a original complete iphone screen, the home button works fine but the touch id dont work. I change the home button to the one that i have in the broken screen and still the touch id dont work. What can i do to fix the touch id?
Juanjo Checo - Ответить
Help! The home button cable attached to the metal front panel ripped a little as I was gently using my fingers to lift it off the screen. Now the home button doesn't work. Did I ruin the phone or is it possible to get a front panel?
Merry Hansen - Ответить
I recently purchased this iFixit kit for my iPhone 6 Plus replacement of my screen that was cracked. I followed the instructions above, and my phone won't turn on. There is a part in to the right of the battery, just below the screen connections, that is really hot. After I noticed it wouldn't turn on, even after plugging it in, I took it back apart, and reseated the connections again. It still doesn't work. I will not purchase this kit again.
Dustin Klumb - Ответить
Bought this recently and I must say that I'm a little bit disappointed:
- the screen doesn't fit as before, you can feel a rough edge - I tried 4 times to put it correctly watching many video tutorials and I had the same result so I assume it's because it's not an original screen
- the colours are not the same anymore, looks like the saturation is on a lower setting - can't see the bright colours anymore
Overall I would rate this part 6 out of 10.
andrewbuta - Ответить
Followed this guide to the letter about 1 week ago. Happy to say its very accurate and my iphone is working 100%
Most difficult and time consuming part was re-inserting the front-facing camera and sensor cable assembly (Step 25) and also removing the home button cable (step 36)
morjo21 - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 41
За последние 7 дней: 251
За последние 30 дней: 730
За всё время: 180,769
