iPhone 7 Logic Board Replacement
Выберете то, что вам нужно
Видео обзор
  1. iPhone 7 Logic Board Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Logic Board Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 7 Logic Board Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 7 Logic Board Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 7 Logic Board Replacement, Anti-Clamp instructions: шаг 3, изображение 1 из 3 iPhone 7 Logic Board Replacement, Anti-Clamp instructions: шаг 3, изображение 2 из 3 iPhone 7 Logic Board Replacement, Anti-Clamp instructions: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Anti-Clamp
    $24.95
    Купить
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 7 Logic Board Replacement: шаг 4, изображение 1 из 3 iPhone 7 Logic Board Replacement: шаг 4, изображение 2 из 3 iPhone 7 Logic Board Replacement: шаг 4, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPhone 7 Logic Board Replacement: шаг 5, изображение 1 из 2 iPhone 7 Logic Board Replacement: шаг 5, изображение 2 из 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone 7 Logic Board Replacement, Heat the display: шаг 6, изображение 1 из 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
  7. iPhone 7 Logic Board Replacement, Separate the display: шаг 7, изображение 1 из 2 iPhone 7 Logic Board Replacement, Separate the display: шаг 7, изображение 2 из 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  8. iPhone 7 Logic Board Replacement: шаг 8, изображение 1 из 3 iPhone 7 Logic Board Replacement: шаг 8, изображение 2 из 3 iPhone 7 Logic Board Replacement: шаг 8, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  9. iPhone 7 Logic Board Replacement: шаг 9, изображение 1 из 3 iPhone 7 Logic Board Replacement: шаг 9, изображение 2 из 3 iPhone 7 Logic Board Replacement: шаг 9, изображение 3 из 3
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  10. iPhone 7 Logic Board Replacement, Screen information: шаг 10, изображение 1 из 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  11. iPhone 7 Logic Board Replacement: шаг 11, изображение 1 из 3 iPhone 7 Logic Board Replacement: шаг 11, изображение 2 из 3 iPhone 7 Logic Board Replacement: шаг 11, изображение 3 из 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  12. iPhone 7 Logic Board Replacement: шаг 12, изображение 1 из 2 iPhone 7 Logic Board Replacement: шаг 12, изображение 2 из 2
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
  13. iPhone 7 Logic Board Replacement: шаг 13, изображение 1 из 3 iPhone 7 Logic Board Replacement: шаг 13, изображение 2 из 3 iPhone 7 Logic Board Replacement: шаг 13, изображение 3 из 3
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
  14. iPhone 7 Logic Board Replacement: шаг 14, изображение 1 из 2 iPhone 7 Logic Board Replacement: шаг 14, изображение 2 из 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  15. iPhone 7 Logic Board Replacement: шаг 15, изображение 1 из 3 iPhone 7 Logic Board Replacement: шаг 15, изображение 2 из 3 iPhone 7 Logic Board Replacement: шаг 15, изображение 3 из 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
  16. iPhone 7 Logic Board Replacement, Battery Disconnection: шаг 16, изображение 1 из 1
    Tri-point Y000 Screwdriver
    $5.99
    Купить
  17. iPhone 7 Logic Board Replacement: шаг 17, изображение 1 из 1
    • Remove the lower connector bracket.
  18. iPhone 7 Logic Board Replacement: шаг 18, изображение 1 из 3 iPhone 7 Logic Board Replacement: шаг 18, изображение 2 из 3 iPhone 7 Logic Board Replacement: шаг 18, изображение 3 из 3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  19. iPhone 7 Logic Board Replacement, Display Assembly: шаг 19, изображение 1 из 3 iPhone 7 Logic Board Replacement, Display Assembly: шаг 19, изображение 2 из 3 iPhone 7 Logic Board Replacement, Display Assembly: шаг 19, изображение 3 из 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  20. iPhone 7 Logic Board Replacement: шаг 20, изображение 1 из 3 iPhone 7 Logic Board Replacement: шаг 20, изображение 2 из 3 iPhone 7 Logic Board Replacement: шаг 20, изображение 3 из 3
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
  21. iPhone 7 Logic Board Replacement: шаг 21, изображение 1 из 2 iPhone 7 Logic Board Replacement: шаг 21, изображение 2 из 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  22. iPhone 7 Logic Board Replacement: шаг 22, изображение 1 из 1
  23. iPhone 7 Logic Board Replacement, SIM Card: шаг 23, изображение 1 из 3 iPhone 7 Logic Board Replacement, SIM Card: шаг 23, изображение 2 из 3 iPhone 7 Logic Board Replacement, SIM Card: шаг 23, изображение 3 из 3
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force. However, ensure the eject tool is properly aligned beforehand as to not damage the eject mechanism inside the phone.
    • Remove the SIM card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  24. iPhone 7 Logic Board Replacement, Logic Board Connectors: шаг 24, изображение 1 из 2 iPhone 7 Logic Board Replacement, Logic Board Connectors: шаг 24, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the rear-facing camera connector.
  25. iPhone 7 Logic Board Replacement: шаг 25, изображение 1 из 2 iPhone 7 Logic Board Replacement: шаг 25, изображение 2 из 2
    • Remove the following Phillips screws securing the rear camera bracket to the rear case:
    • One 1.3 mm screw
    • One 2.5 mm screw
  26. iPhone 7 Logic Board Replacement: шаг 26, изображение 1 из 1
    • Remove the bracket.
  27. iPhone 7 Logic Board Replacement: шаг 27, изображение 1 из 2 iPhone 7 Logic Board Replacement: шаг 27, изображение 2 из 2
    • Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
  28. iPhone 7 Logic Board Replacement: шаг 28, изображение 1 из 1
    • Remove the two 1.2 mm tri-point screws securing the upper cable bracket.
  29. iPhone 7 Logic Board Replacement: шаг 29, изображение 1 из 2 iPhone 7 Logic Board Replacement: шаг 29, изображение 2 из 2
    • Remove the upper cable bracket.
  30. iPhone 7 Logic Board Replacement: шаг 30, изображение 1 из 2 iPhone 7 Logic Board Replacement: шаг 30, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the upper cable connector.
  31. iPhone 7 Logic Board Replacement: шаг 31, изображение 1 из 2 iPhone 7 Logic Board Replacement: шаг 31, изображение 2 из 2
    • Remove the four Phillips screws securing the Wi-Fi antenna:
    • Three 1.2 mm screws
    • One 1.7 mm screw
  32. iPhone 7 Logic Board Replacement: шаг 32, изображение 1 из 2 iPhone 7 Logic Board Replacement: шаг 32, изображение 2 из 2
    • Remove the top left antenna.
  33. iPhone 7 Logic Board Replacement: шаг 33, изображение 1 из 1
    • Remove the following Phillips screws:
    • One 1.3 mm screw
    • One 2.2 mm screw
  34. iPhone 7 Logic Board Replacement: шаг 34, изображение 1 из 2 iPhone 7 Logic Board Replacement: шаг 34, изображение 2 из 2
  35. iPhone 7 Logic Board Replacement: шаг 35, изображение 1 из 1
    Standoff Screwdriver for iPhones
    $5.49
    Купить
    • Remove the 2.2 mm standoff screw from the grounding bracket.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  36. iPhone 7 Logic Board Replacement: шаг 36, изображение 1 из 2 iPhone 7 Logic Board Replacement: шаг 36, изображение 2 из 2
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
  37. iPhone 7 Logic Board Replacement, Logic Board: шаг 37, изображение 1 из 3 iPhone 7 Logic Board Replacement, Logic Board: шаг 37, изображение 2 из 3 iPhone 7 Logic Board Replacement, Logic Board: шаг 37, изображение 3 из 3
    • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
  38. iPhone 7 Logic Board Replacement: шаг 38, изображение 1 из 3 iPhone 7 Logic Board Replacement: шаг 38, изображение 2 из 3 iPhone 7 Logic Board Replacement: шаг 38, изображение 3 из 3
    • Use tweezers to gently derout the antenna cables from the metal bracket on the logic board.
  39. iPhone 7 Logic Board Replacement: шаг 39, изображение 1 из 2 iPhone 7 Logic Board Replacement: шаг 39, изображение 2 из 2
    • Use the point of a spudger to disconnect the lower cable connector.
  40. iPhone 7 Logic Board Replacement: шаг 40, изображение 1 из 1
    $5.49
    Купить
    • Remove the following screws:
    • One 1.4 mm Phillips screw
    • Three 2.2 mm standoff screws
    • Standoff screws are best removed using a standoff driver.
  41. iPhone 7 Logic Board Replacement: шаг 41, изображение 1 из 2 iPhone 7 Logic Board Replacement: шаг 41, изображение 2 из 2
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
  42. iPhone 7 Logic Board Replacement: шаг 42, изображение 1 из 2 iPhone 7 Logic Board Replacement: шаг 42, изображение 2 из 2
    • Use the flat end of a spudger to gently lift the battery connector end of the logic board up.
    • Make sure you're not pulling against any cables. If you feel resistance, check all cables, connectors, and components are clear of the board.
  43. iPhone 7 Logic Board Replacement: шаг 43, изображение 1 из 3 iPhone 7 Logic Board Replacement: шаг 43, изображение 2 из 3 iPhone 7 Logic Board Replacement: шаг 43, изображение 3 из 3
    • Lift the battery connector end of the logic board and pull it up and out of the rear case.
    • Be careful not to snag the logic board on any cables.
Заключение
158 участников успешно повторили данное руководство.
Evan Noronha
Участник с: 02/05/15
223 466 Репутация
Автор 168 руководств
13 Комментариев
I had an accident where my iphone has got some damage (cracked screen, metal frame slightly bent).. I can see a lot of iCloud locked devices for sale, some of them for a cheap price. Would replacing the logic board and home button give me a non-damaged working phone? Or what parts would need to be moved for this? Sure I can buy a brand new phone but I like a bit of a challenge :)
Steve - Ответить
the logic board holds the OS, so yes if you were to replace the mother board of the iPhone it should work like a new phone but without touch id
Vegas Uprising -
I have the same idea and i found to buy this one
https://www.aliexpress.com/item/For-iPho...
You think it will work?
alexandros papadopoulos -
Hi,
I’ve got a problem with my iphone7. I just took some videos under the water using my iphone. But later it’s finger id has gone and it’s fully damaged. Now the phone is not working. Is there any option to repair this ….?
muhammed faisal - Ответить
Hi Muhammed, sounds like some water got inside your phone. Check out our iPhone liquid damage guide for some basic troubleshooting you can do on your own. When you have the phone open check connectors and pins on the board for any corrosion. If the damage is serious enough that cleaning won’t fix it, you can take your phone to a local repair shop for more extensive repairs.
Adam O'Camb -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 30
За последние 7 дней: 160
За последние 30 дней: 814
За всё время: 272,272
