iPhone 7 Speaker Replacement
Выберете то, что вам нужно
Видеообзор
  1. iPhone 7 Speaker Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Speaker Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 7 Speaker Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 7 Speaker Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  3. iPhone 7 Speaker Replacement, Anti-Clamp instructions: шаг 3, изображение 1 из 3 iPhone 7 Speaker Replacement, Anti-Clamp instructions: шаг 3, изображение 2 из 3 iPhone 7 Speaker Replacement, Anti-Clamp instructions: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 7 Speaker Replacement: шаг 4, изображение 1 из 3 iPhone 7 Speaker Replacement: шаг 4, изображение 2 из 3 iPhone 7 Speaker Replacement: шаг 4, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPhone 7 Speaker Replacement: шаг 5, изображение 1 из 2 iPhone 7 Speaker Replacement: шаг 5, изображение 2 из 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone 7 Speaker Replacement, Heat the display: шаг 6, изображение 1 из 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
  7. iPhone 7 Speaker Replacement, Separate the display: шаг 7, изображение 1 из 2 iPhone 7 Speaker Replacement, Separate the display: шаг 7, изображение 2 из 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  8. iPhone 7 Speaker Replacement: шаг 8, изображение 1 из 3 iPhone 7 Speaker Replacement: шаг 8, изображение 2 из 3 iPhone 7 Speaker Replacement: шаг 8, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  9. iPhone 7 Speaker Replacement: шаг 9, изображение 1 из 3 iPhone 7 Speaker Replacement: шаг 9, изображение 2 из 3 iPhone 7 Speaker Replacement: шаг 9, изображение 3 из 3
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  10. iPhone 7 Speaker Replacement, Screen information: шаг 10, изображение 1 из 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  11. iPhone 7 Speaker Replacement: шаг 11, изображение 1 из 3 iPhone 7 Speaker Replacement: шаг 11, изображение 2 из 3 iPhone 7 Speaker Replacement: шаг 11, изображение 3 из 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  12. iPhone 7 Speaker Replacement: шаг 12, изображение 1 из 2 iPhone 7 Speaker Replacement: шаг 12, изображение 2 из 2
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
  13. iPhone 7 Speaker Replacement: шаг 13, изображение 1 из 3 iPhone 7 Speaker Replacement: шаг 13, изображение 2 из 3 iPhone 7 Speaker Replacement: шаг 13, изображение 3 из 3
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
  14. iPhone 7 Speaker Replacement: шаг 14, изображение 1 из 2 iPhone 7 Speaker Replacement: шаг 14, изображение 2 из 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  15. iPhone 7 Speaker Replacement: шаг 15, изображение 1 из 3 iPhone 7 Speaker Replacement: шаг 15, изображение 2 из 3 iPhone 7 Speaker Replacement: шаг 15, изображение 3 из 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
  16. iPhone 7 Speaker Replacement, Battery Disconnection: шаг 16, изображение 1 из 1
    Tri-point Y000 Screwdriver
    $5.99
  17. iPhone 7 Speaker Replacement: шаг 17, изображение 1 из 1
    • Remove the lower connector bracket.
  18. iPhone 7 Speaker Replacement: шаг 18, изображение 1 из 3 iPhone 7 Speaker Replacement: шаг 18, изображение 2 из 3 iPhone 7 Speaker Replacement: шаг 18, изображение 3 из 3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  19. iPhone 7 Speaker Replacement, Display Assembly: шаг 19, изображение 1 из 3 iPhone 7 Speaker Replacement, Display Assembly: шаг 19, изображение 2 из 3 iPhone 7 Speaker Replacement, Display Assembly: шаг 19, изображение 3 из 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  20. iPhone 7 Speaker Replacement: шаг 20, изображение 1 из 3 iPhone 7 Speaker Replacement: шаг 20, изображение 2 из 3 iPhone 7 Speaker Replacement: шаг 20, изображение 3 из 3
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
  21. iPhone 7 Speaker Replacement: шаг 21, изображение 1 из 2 iPhone 7 Speaker Replacement: шаг 21, изображение 2 из 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  22. iPhone 7 Speaker Replacement: шаг 22, изображение 1 из 1
  23. iPhone 7 Speaker Replacement, Barometric Vent: шаг 23, изображение 1 из 1
    • Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
  24. iPhone 7 Speaker Replacement: шаг 24, изображение 1 из 2 iPhone 7 Speaker Replacement: шаг 24, изображение 2 из 2
    • Remove the vent.
  25. iPhone 7 Speaker Replacement, Taptic Engine: шаг 25, изображение 1 из 2 iPhone 7 Speaker Replacement, Taptic Engine: шаг 25, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
  26. iPhone 7 Speaker Replacement: шаг 26, изображение 1 из 1
    • Remove the three 1.6 mm Phillips screws securing the Taptic Engine to the rear case.
  27. iPhone 7 Speaker Replacement: шаг 27, изображение 1 из 2 iPhone 7 Speaker Replacement: шаг 27, изображение 2 из 2
    • Remove the Taptic Engine.
  28. iPhone 7 Speaker Replacement, Speaker Assembly: шаг 28, изображение 1 из 1
    • Remove the Phillips screw securing the Wi-Fi diversity antenna to the rear case:
    • One 3.2 mm screw
  29. iPhone 7 Speaker Replacement: шаг 29, изображение 1 из 1
    • Remove the following three Phillips screws securing the speaker to the rear case:
    • Two 1.3 mm screws
    • One 2.0 mm screw
  30. iPhone 7 Speaker Replacement: шаг 30, изображение 1 из 3 iPhone 7 Speaker Replacement: шаг 30, изображение 2 из 3 iPhone 7 Speaker Replacement: шаг 30, изображение 3 из 3
    • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
  31. iPhone 7 Speaker Replacement: шаг 31, изображение 1 из 2 iPhone 7 Speaker Replacement: шаг 31, изображение 2 из 2
    • Use tweezers to derout the antenna cables from their bracket on the logic board.
  32. iPhone 7 Speaker Replacement: шаг 32, изображение 1 из 2 iPhone 7 Speaker Replacement: шаг 32, изображение 2 из 2
    • Use tweezers to remove the antenna cables from the clip on the speaker.
    • Make sure to grasp the cable near the clip in order to avoid damaging the cable.
  33. iPhone 7 Speaker Replacement: шаг 33, изображение 1 из 2 iPhone 7 Speaker Replacement: шаг 33, изображение 2 из 2
    • Use the tip of a spudger to slide the speaker assembly towards the logic board and off of the rear case.
  34. iPhone 7 Speaker Replacement: шаг 34, изображение 1 из 1
    • Remove the speaker.
  35. iPhone 7 Speaker Replacement, Wi-Fi Diversity Antenna: шаг 35, изображение 1 из 2 iPhone 7 Speaker Replacement, Wi-Fi Diversity Antenna: шаг 35, изображение 2 из 2
    • Gently remove the antenna from the clip on the speaker.
  36. iPhone 7 Speaker Replacement: шаг 36, изображение 1 из 2 iPhone 7 Speaker Replacement: шаг 36, изображение 2 из 2
    • Gently remove the tab by lifting up with tweezers and separate the tab from the speaker.
  37. iPhone 7 Speaker Replacement: шаг 37, изображение 1 из 1
    • Remove the Wi-Fi diversity antenna.
Заключение
69 человек успешно провели ремонт по этому руководству.
Evan Noronha
Участник с: 02/05/15
228 544 Репутация
Автор 168 руководств
9 Комментарии к руководству
My right speaker is currently not working, and I think I will probably be doing his soon on my device. Thank you.
Alexander Wiand - Ответить
Hi there
My iPhone 7 has static when calling and the person im calling cannot hear me. Can someone help me or tell me what is the problem? Is it the earpiece speaker or the speaker at the bottom of the iPhone? Please somebody. Thanks.
Deverard Devereux - Ответить
Hi. I’ve the same problem. Have you fix with changing?
Alessandro -
I did all and now the iphone is not turning on
Raul G - Ответить
that’s really sad. would you may have damaged to any cell while disassembling? because there is no chance for not turning the phone on, if you did it properly.
Sjen -
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 9
За последние 7 дней: 72
За последние 30 дней: 401
За всё время: 103,088
