iView-776TPCII Camera Assembly Replacement
Выберете то, что вам нужно
  1. iView-776TPCII Camera Assembly Replacement, Rear Panel: шаг 1, изображение 1 из 3 iView-776TPCII Camera Assembly Replacement, Rear Panel: шаг 1, изображение 2 из 3 iView-776TPCII Camera Assembly Replacement, Rear Panel: шаг 1, изображение 3 из 3
    • Before disassembling your device, make sure that the power is completely turned off.
    • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
    • The clips may take some pressure before releasing.
    • Continue around the entire device until all of the clips have been released.
    Спросите у FixBot
    Добавить комментарий
  2. iView-776TPCII Camera Assembly Replacement: шаг 2, изображение 1 из 2 iView-776TPCII Camera Assembly Replacement: шаг 2, изображение 2 из 2
    • Use a spudger to carefully free the speaker from it's housing on the back panel.
    • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
    • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
    Спросите у FixBot
  3. iView-776TPCII Camera Assembly Replacement, Camera Assembly: шаг 3, изображение 1 из 2 iView-776TPCII Camera Assembly Replacement, Camera Assembly: шаг 3, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Heavy-Duty Spudger
    • The camera module is located in the upper-right corner of the tablet.
    • Loosen the edges of the black tape covering the camera using the heavy-duty spudger.
    • Use the freed edges of the tape to gently remove the camera assembly from its plastic housing.
    • The camera assembly will still be connected to the rest of the device via a ribbon cable. Take care so as not to tear this connection.
    Спросите у FixBot
  4. iView-776TPCII Camera Assembly Replacement: шаг 4, изображение 1 из 2 iView-776TPCII Camera Assembly Replacement: шаг 4, изображение 2 из 2
    • Use tweezers to lift the cover off the top of the camera's ZIF adapter.
    • When reassembling the device, be sure to fully secure the ribbon cable from the camera back into the ZIF adapter.
    • Pull the assembly away from the motherboard with a set of tweezers to prepare for desoldering.
    Спросите у FixBot
  5. iView-776TPCII Camera Assembly Replacement: шаг 5, изображение 1 из 1
    • Use the Portable Soldering Iron tool to heat the leads coming from the camera assembly to the motherboard, thereby breaking the connection.
    • For help on soldering, refer to the iFixit "How To Solder and Desolder Connections" technique guide as necessary.
    • Once heated, use tweezers to pull the wires free from their connections.
    • To ease reassembly, take note of which wire went to the positive and negative terminals.
    Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Cory Gratzer
Участник с: 09/16/15
586 Репутация
Автор 5 руководств
Команда
IUPUI, Team 2-2, Baechle Fall 2015 Участник IUPUI, Team 2-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G2
3 членов
Автор 12 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 23
За всё время: 609
