Вики, созданная, благодаря помощи студентов
Эта вики выполнена отличной студенческой командой из нашей образовательной программы.
The Power Jack does not work
The cable connection to the computer is weak/nonexistent.
Debris in the Power Jack
Check the power jack for possible obstructions. You could blow air into the jack, or purchase a specialized cleaning device, such as compressed air.
Damaged Power Jack
Check for possible damage to the power jack on both the cable and the computer. If the damage is on the cable, you should purchase a new one. If it is on the computer, see Toshiba Satellite C50D-A Power Jack Replacement.
The CD Player is not working
The CD player isn't functioning properly. The computer doesn't register the CD, or won't play it.
CD is broken
Examine your CD to determine whether it is scratched, or broken. Try using it on a different device to see if it has a similar issue.
CD Player is broken
This may be caused by physical or water damage. In this case, you would have to replace your CD player, see Toshiba Satellite C50D-A Optical Drive Replacement.
The computer is overheating
Your computer turns off unexpectedly, or becomes hot.
Defective Battery
Inspect the battery to see if it needs to be replace by following Toshiba Satellite C50D-A Battery Replacement guide to replacing your battery.
Broken Fan
Can you determine if the issue is due to dust or a broken part? If it is dust, purchase an air compressor and blow it into the air vents on the bottom of your laptop. If not, see Toshiba Satellite C50D-A Fan Replacement.
The computer will not charge
The computer will not start charging, even though it is plugged in.
Cable isn't connected
Check to make sure the cable is plugged into the correct space and that it is connected to an outside power source -- the outlet. Make sure that everything is properly plugged in.
Computer needs to reboot
Try restarting your computer, by pressing and holding the power button for at least 20 seconds. If that doesn't work, see the Toshiba Satellite C50D-A Battery Replacement
A blank screen keeps appearing
The computer display is completely blank when it is turned on.
Frozen Computer
RAM is defective
If restarting your computer doesn't work, see the following Toshiba Satellite C50D-A RAM Replacement to replace your RAM.
Один комментарий
Hi
just installed windows 10 on Toshiba c50d-a went to use my computer today and put it password just comes up with the welcome and the little circles spinning around. Can not get passed it. Does anyone know how to fix this??
Alison - Ответить
