Вики, созданная, благодаря помощи студентов
Эта вики выполнена отличной студенческой командой из нашей образовательной программы.
Device Will Not Power On
The computer does not power on when the power button is pressed.
Battery Has Insufficient Charge
If your device is not connected to an AC adapter and will not turn on, you may need to charge your battery. Plug the AC adapter into the charging port on the device, ensuring that the indicator light turns on. If the charging indicator light does not turn on, your AC adapter may be faulty.
Faulty AC Adapter
If the charging indicator light on your device does not turn on when you plug your AC adapter into it, your AC adapter might be faulty. To check it, follow these steps:
- Unplug your AC adapter first from your computer, and then from the wall socket.
- Ensure the power cable is properly and securely connected to the adapter box.
- Inspect the cables for bends, breaks, or exposed wire. If any are found, you may want to consider replacing your AC adapter.
- Remove the battery from your device.
- Plug the power cable attached to the AC adapter into a wall socket, and plug the adapter into the device charging port.
- Attempt to power on your device. If it will not power on, consider purchasing a replacement AC adapter.
Note that if your device will power on only when the AC adapter is plugged in, you may have a faulty battery.
Faulty Battery
If your device will only power on when the AC adapter is connected, your battery might no longer hold a charge. To test this, turn off the device and leave the AC adapter connected for the standard charging time. Then, disconnect the AC adapter and attempt to turn the device on. If this fails, you may need to replace your battery. Learn how to do so here.
Battery Will Not Charge
Device battery is not receiving or maintaining power.
Faulty Battery
If your device’s charging indicator light is on, and the device will power on only when the AC adapter is connected, you may have a faulty battery. To replace it, follow these instructions.
Faulty AC Adapter
If your device’s battery is not charging, you may have a faulty AC adapter. First, disconnect the adapter from the wall socket and from your device. Inspect all cables for signs of damage, bends, or breakage. If any are found, consider replacing your AC adapter. If the adapter appears to be in good shape, ensure the power cable is securely connected to the adapter box. Plug the adapter’s power cable into a working wall socket, then connect the adapter to your device’s charging port. Check to ensure the charging indicator light has turned on. If no light appears, you may have a faulty AC adapter.
If your device’s charging indicator light is on, but your device will not hold or maintain a charge, the device’s battery may be faulty.
Touch Pad Will Not Respond
Device receives no input from touch pad.
Driver Out Of Date
If your device boots successfully, but does not receive input from the touch pad, your device drivers may be out of date. To update them, use keyboard keys to navigate to your device manager and update your drivers. If you are unsure of how to do this, follow these instructions:
- Ensure your device is connected to the internet.
- Press the “Windows” key on your keyboard. This is the key with the Windows logo on it.
- Type “device manager” in the search box, and press enter.
- Press tab once to highlight the device categories.
- Using the keyboard’s arrow keys, navigate downwards to “Human Interface Devices”.
- Press the right arrow key to open the sub-menu.
- Using the arrow keys, navigate down to “HID-Compliant touch pad”. Press enter.
- On the properties screen, press shift+tab to highlight the tabs.
- Press the right arrow key to navigate to “Driver”.
- Press tab twice to highlight “Update Driver”. Press enter.
- Press enter to select “Search automatically for updated driver software”.
If your device’s driver are updated to their most recent versions and your device still receives no input from the touch pad, your touch pad may be faulty.
Faulty Touch Pad
If your device’s drivers are up to date and your device receives no input from the touch pad, your touch pad may be faulty.
Screen Is Blue
Device display shows a blue screen, possibly with an error code. A blue screen with an error message is commonly referred to as “Blue Screen of Death”.
Corrupted Installation
If any new applications were installed on your device before you experienced the blue screen issue, you could have a corrupted installation. To fix this problem, follow these instructions:
- Boot Windows in Safe Mode. To do this from a blank blue screen, you will need to manually restart your computer three times by holding down your device’s power button. Simply hold the button down until the device powers down, and press once to turn it back on. Count five seconds, then repeat. Count five seconds again, and repeat a final time. Your PC will enter the Windows Recovery Environment.
- On the “Choose an Option” screen, select “Troubleshoot”, followed by “Advanced Options”, then “Startup Settings”. Select “restart”.
- When your device restarts, the screen will list options. Press F5 on your keyboard to select “Safe Mode with Networking”. Allow system to boot.
- Press your Windows key, and type in “Add or Remove Programs”. Press enter.
- On the next screen, uninstall any new or recently-installed applications.
If your device continues to blue screen, you may be experiencing a Windows error.
Windows Error
Blue Screens of Death typically display a Windows error code or message. This code could be a series of words, letters, or numbers, depending on the cause of the error. If your device is displaying a blue screen with an error message, learn how to locate your error code and diagnose your problem here.
If there is no error code or message on your screen, you may have a faulty driver.
Faulty Drivers
Sometimes, blank blue screens are caused by faulty drivers. To fix this issue, you will need to update your drivers following these instructions.
- Press the Windows logo key. Type “check for updates” in the search box, and press enter.
- On the “Windows Update” screen, click “Check for Updates”.
Once your drivers have been updated, restart your device using the shutdown menu.
If your device continues to blue screen, your CPU may be overheating.
CPU Overheat
If your device is experiencing CPU overheat, it may display a blue screen, power down without warning, or fail to boot. Follow the steps bellow to diagnose this problem.
Windows Error Code
Blue screens often display a Windows error code. Use this guide to read your error code.
If your error code indicates CPU overheat, you may need to replace your CPU heat sink. Use this guide to safely remove and replace the component.
If your device is not displaying a Windows error code, there are physical and auditory symptoms that coincide with CPU overheat.
Beeping and Venting Hot
If your CPU is overheating, your device may emit several beeps while attempting to boot. If this happens, your device may also fail to boot, and the device fans will blow very hot air. If these symptoms are present, you may need to replace your heat sink. Find out how to safely and efficiently do so here.
If your device shows no signs of CPU overheat, other hardware inside of your device could be malfunctioning.
Faulty Hard Drive
Another common reason a device may display a blue screen is hard drive failure. Below are two ways to diagnose this problem.
Windows Error Code
If the error code returns as a hard drive malfunction, you may need to replace your hard drive. Follow the steps outlined here to make quick work of the job. Be sure to back up all data on your current hard drive if possible.
Your device’s blue screen may not display an error code, but the device might be making a clicking noise.
Clicking Noise
Hard drive failure is often first indicated by a clicking noise. If present, this clicking sound will occur while your device is powered on. Listen closely to determine if the noise is present and, if so, follow the steps outlined here to replace your hard drive. Be sure to back up all data on your current hard drive if possible.
If your device shows no indication of hard drive failure, other components inside your device may be malfunctioning.
Faulty RAM
RAM failure might also prompt your device to display a blue screen. Below are two possible ways to diagnose this problem.
Blue Screen Error Code
Blue screens often display a Windows Error code. Use this guide to read your error code.
If the error code returns as a RAM malfunction, you may need to replace your RAM. Follow the steps outlined here to make quick work of the job.
If your device’s blue screen displays no error code, there is another way to see if your RAM is the issue.
Windows Memory Diagnostic
Follow the directions below to diagnose RAM malfunctions with no Windows error code.
- Pres the Windows logo key. Type “Windows Memory Diagnostic” into the search box, and press enter.
- Select Windows Memory Diagnostic when it appears.
- Select “Restart now and check for problems”.
- Allow the test to complete.
If your device’s RAM is functioning properly, Windows will display a message saying “The Windows Memory Diagnostic tested the computer’s memory and detected no errors”.
If your device’s RAM is faulty, Windows will display a report indicating what errors it found in each attached RAM stick. Follow these instructions to safely replace your RAM.
No Audio Plays
No sound plays from device speakers or accessory connected to headphone port.
Device is Muted
If no sound is playing from your device’s speaker or from an accessory plugged into the headphone port, the device volume might be muted. To check this, right-click the volume icon in the lower right corner of your screen, and select “volume mixer”. Ensure that your device volume is set to the level of your choice, and close the window.
If your device is not muted and still emits no sound through the speakers or an audio device connected to the headphone port, your drivers may be faulty or out-of-date.
Faulty Drivers
If no sound is coming from a connected accessory or the device’s speakers, your sound drivers may be out of date or faulty. To update them, follow these instructions:
- Restart your device. Often, this solves the problem. If the issue persists, proceed to step 2.
Once your drivers have been updated, restart your device using the shutdown menu. If your device is not muted, the drivers are up-to-date, and there still is no sound from the speakers or an accessory connected to the headphone port, you may have faulty hardware.
Faulty Hardware
If your device is not muted, the drivers are up-to-date, and there is either no sound or crackling noise coming from your device’s speakers, the speakers may be faulty, and will need to be replaced. Learn how to replace them here.
If sound comes from your device’s speakers, but not from an accessory connected to the headphone port, your accessory audio device may be faulty. Try plugging in a different but similar audio accessory. If this accessory works, consider replacing the non-working audio accessory.
0 Комментариев
