ATTENTION ALL THOSE WHO HAVEN'T FOUND A FIX: If you followed all the different instructions here, but nothing worked, try the following.
Warning: You have to take the back off of the tablet...
I did this by carefully inserting a small swiss army knife into the top part of where the backing snaps onto the screen, and then took a guitar pick in place of the knife, and slowly went around the whole thing gently leveraging the backing until all the snap points are loose. If you get all the sides except the bottom, which seemed to be the most fragile, you should be able to take the backing off and the bottom will unhook by itself.
After the backing is off, you must unplug the battery from the motherboard. It's a black, connector with 6 short wires running at the top of the battery. I used the same small swiss army knife to GENTLY lift the plastic on top of the connector so the locking, inserted portion of the connector wiggles free. Use your fingernail to pull one side of the connector, and then the other until it is disconnected.
Leave it disconnected for a few minutes. At this point, I plugged the USB plug into it while the battery was disconnected for about 2 seconds, but I DOUBT this had anything to do with the fix, as I heard it make very high pitched wine like it was overloading a transformer or transistor. Only try it if disconnecting the batter alone doesn't help.
At this point, reconnect the battery, and press the power button for about two seconds. My T100 powered right up. If it powers up, carefully pop the backing in place and hope to god that it doesn't do it again... :D if not, you're SOL.
FYI: my symptoms were that it would flash white when trying to power on the normal way, and then nothing would happen, and when plugged in, the LED by the power button would be solid white. When trying to power on while on the charger, it would do the same flashing white LED by the power button, and nothing would happen. None of the button pressing combinations did anything. The screen never turned on or flickered, and the LED by the camera did NOT illuminate when I would try to turn it on.
Hope this helps someone...
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
16
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
57 Комментариев
The white light is on when I have it plugged in but doesn't do anything. I have tried holding the button down for 2 seconds, 10 seconds etc. When I unplug it, the power white light button goes off. Anyone know how to fix this/reset it?
из chefmjb21
i turn on my laptop and show the green power light is on but it doesn't turn on
из graymdigo
I'm having the same problem again. I posted this in July. It is now November, 3 months later, and the same thing is happening. This is an issue.
из NiNiBeanz
Same just had mine for a day and it won't turn on
из harrisnparker
Just got my laptop today for Christmas....I charged it and then used it for a couple minutes just loading some pics and basic setup stuff then left it sitting a few minutes and when I came back the screen was off and wouldn't come back on so I shut it it down and now it won't come on at all and the charging light doesn't come on when I plug it in....there is no way to "pull the battery" to reset as I have seen suggested so.....what to do?!?!
из jaxmommy1413
Показать 52 больше комментариев
