Why is there no sound?
The volume is up fully and will not produce any noise! Help!
Это хороший вопрос?
Это хороший вопрос?
You might have a bad speaker or audio jack. In the case of the speaker you would need to check the connection between the speaker and motherboard. If it was due to the audio jack, cleaning it with an air duster may help. Check out the Troubleshooting page if you any issues.
Был ли этот ответ полезен?
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 39
За всё время: 7,113
4 Комментариев
What is the exact model of phone you have? That way I will be able to further help you know what the exact problem is with your phone.
из computeripodrepair
@computeripodrepair, LeapFrog LeapPad2 Explorer is a childrens learning tablet, not a phone!
из oldturkey03
Andrew Gough, what have you tried so far? how long has this been going on? Has anything happened just prior to it failing?
из oldturkey03
My daughter own is the same problem no sound
из asheena lawson
