static image and colorful screen
The problem start two weeks ago, the screen started to fail but the problem it's getting more frequently, if I use my phone for 10 seconds the image get freeze, if I turn off and turn on the screen, it shows a colorful static image like old tv without signal, if I turn off the screen for a minute, when I turn it on again, the phone works well for almost ten seconds and get stuck again but is only de image, the phone continue working with the freeze or the colorful image
I read that it could be the the part "USB Port Dock Connector Mic Flex Cable" but I want to confirm before buy it
thanks in advance
Note: the second image is not mine, I use one found in a forum but it show the same problem
Это хороший вопрос?
Счет 4
2 Комментариев:
any solutions ?
из
yes, I fixed it changing the flex usb charge port
из
Добавить комментарий
4 Ответов
Left my Nexus 5 for about 10 minutes, took it up to check message and the screen was the same as the second picture. Tried rebooting the phone, however nothing seems to work nor does the rebooting screen comes up
Был ли этот ответ полезен?
Счет 0
My phone started showing that screen with low frequency, now if I keep the display on for one minute the screen show the static-y screen
Счет 0
I have the same issue. Looking on forums I found the problem. You need to replace the FLEX USB charge port.
I´m looking on ebay to buy one.
Счет 0
Have you fixed it...i have same problem...help
Счет 0
1 Комментарий:
из
Добавьте свой ответ
Alexander Morales Sevilla буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 30
За всё время: 2,647
