Этот 5-квартовый миксер с откидной головкой доступен более чем в 25 цветах. Он оснащен полированной чашей из нержавеющей стали с ручкой и двигателем мощностью 325 Вт, что делает его мощнее моделей серии Classic.
Will not turn off
I have a Kitchen Aid Artisan stand mixer, about 5 years old. The switch will not stay in the off position, but will move (all by itself) into the stir position. If I tighten the recommended screw, it solves this problem, but then the mixer runs at a much higher speed and will not run at low speeds at all.
A question that was asked previously is similar to mine:
Doesn't actually turn off
If it is a part that needs to be replaced, I would appreciate a new link to the part that I need as the old link is now broken. If I need to test if a switch is bad, if you could let me know exactly how to do that, that would be great as well.
Thank you in advance.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
I have fixed this exact problem before.
The speed lever linkage has a spring which stretches from the inside of the housing to the bottom of the Control Board (CB) . This pulls on the bottom of the CB keeping it pressed against the piece which pushed it out as the speed is increased (thus returning it back again as the speed is reduced and/or turned off).
The problem comes in when the spring pull overcomes the stops (notches) which hold the speed slider in place at each setting. There is a screw which can only be found when the motor housing is opened and which holds the speed lever linkage in place. If this (internal) screw is loose, the slider will not properly engage the stops and the spring pulls it out of the off position. If this screw is still tight and the slider still does not engage the stops properly, then the slider needs a slight bend to encourage it to engage the stops with a bit more force.
The Service Manual shows the whole assemble and can be downloaded from:
http://www.kitchenaidparts.eu/documents/...
Был ли этот ответ полезен?
Счет 3
Добавьте свой ответ
acbeer буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 22
За последние 30 дней: 41
За все время: 4,491
