G&G Combat Machine 16 Carbine — это полностью металлический страйкбольный автоматический электропневматический привод (AEG), созданный по образцу карабина M4.
Motor straining while firing
I have this exact rifle. It has the blow back feel to it as well.
Lately while trying to fire it, it sounds as if the motor is straining, it fires intermittently and freezes. The batteries are fine and i have occasionally put a drop of silicone lube on a few BB's.
Before i use the guide to take it apart, i would like to know if there is anything specific i need to be aware of or if there are any known issues with the rifle which could be causing this.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
The first thing I would do is paint it bright orange all over.
Next try replacing the battery: http://www.evike.com/products/24483/
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
I have three batteries. All fully charged.
It doesnt make a difference. I am going to replace the motor with a high torque one and replace the appropriate internals to accept a M140 spring.
из Поделиться
I said that because a combat vet might see this and fire before noticing the orange tip. I did not see the tip at first and this toy could get you killed in a hurry.
из Поделиться
Добавьте свой ответ
Will буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 13
За последние 30 дней: 32
За все время: 700
