Skullcandy Air Raid — это беспроводная портативная Bluetooth-колонка, выпущенная 15 ноября 2013 года, которая транслирует музыку с любого устройства с поддержкой Bluetooth.
Why wont my device charge?
I have checked my wall outlet and it works perfectly fine with charging other plug-in devices, it just seems to be a problem with my Air Raid. What should I do?
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
If the outlet is working and your device is still not charging, you may have a bad USB port. If your device only charges when the plug is held at a certain angle, will not plug in all the way, or has visibly bent/broken pieces inside the charging port, you should replace the USB port. If you have left the Air Raid charging for a long time, but the battery dies quickly after unplugging it, you may need to replace the battery.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
You should try going to Skullcandy Air Raid Troubleshooting for more troubleshooting help
из
Where do i purchase a new battery?
из
@Sasha Nevin, SAME!! IDK what to do about it, but it is really annoying. I've had to use earphones (the ones u stick in ur ear) and was trying to get away from those, however it just won't charge! I also tried charging it through my computer, therefore it still didn't charge
Счет 0
Добавьте свой ответ
Sasha Nevin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 5,348
