Этот дрон поддерживает Wi-Fi и оснащен встроенной HD-камерой. Он используется для фото- и видеосъемки. Номер модели: PF722000
Bebop drone - Camera front glass
Hello.
I have scrached the grass of the camera (bebop drone). Is there a way to change the glass? This product (EPP nose) doesn't contain glass? I mean... the glass in front of the bebop is the camera glass without any protection?
Thanks a lot
Это хороший вопрос?
Счет 6
Добавить комментарий
5 Ответов
Наиболее полезный ответ
You can try this:
http://chtech.co.za/wordpress/parrot-beb...
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Please can you contact me at harrisonashley8357@gmail.com thankyou regarding your diy lens
из
Check out this: https://www.youtube.com/watch?v=uyO5qx81...
I haven't tried it yet, but need too. I scratched the lens of my Bebop as well, but don't need to replace the entire camera. I hope iFixit can source the replacement lens for us: that would make life a LOT easier!!!!
- Jeff
Счет 0
The result is in focus but one can clearly see the effect of the lack of anti-glare coating.
Счет 0
My front broke can it be replaced
Счет 0
If it’s out of focus than it’s easy fix; all you’ll need to do is to watch YouTube video.
but sometimes the camera itself is broken & if you attempt to turn on your Bebop that all it gives you is Blinking green light & nothing else.
to fix this problem all you’ll need to do is to watch another YouTube video while you remove the front Nose, remove the Camera housing, than disconnect it from the MotherBoard; Screw it back together & you’ll have a working Drone without the FVP(Camera view) but you can still fly it whiteout any problems.
All Thanks to parrot.com to have &&^&@@ us all; They manufacture Bebop Camera Replacement but for $300+ that they can go stick their heads up their ass, as I’m sure by now it’s the exact fit.
Счет 0
Добавьте свой ответ
cinepallas2 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 17
За всё время: 9,839
