Руководства по ремонту и поддержка для кухонных и ванных смесителей и кранов.
How to stop a dripping faucet
How to stop the faucet from dribbling water?
Every sink in my house drip's water! Please inform me on how to fix my dribbling faucet's. Its wasting so much water especially since we ,Califotnian's are in a huge water drought. Thank you
Это хороший вопрос?
Счет 7
2 Комментариев
Not only are all my sinks dripping, but my tub spigot as well. Is the solution the same? I live on Galveston Island in Texas
из
How much calcium deposit build up are getting on your faucets? Could you post a picture of one with heavier buildup?
из
Добавить комментарий
3 Ответов
Выбранное решение
Nancy Wilder, you seem to have some issues with minerals in your water that build up inside your faucet :-). The repairs are not really that complicated but can be tedious. Most leaky compression faucets will need new seat washers. Pry off the decorative cap on the handle, remove the handle screw, pull off the handle and use a crescent wrench to unscrew the packing nut. After unscrewing the stem, remove and replace the seat washer held in place by a brass screw. Always make sure that you cut the water supply to the faucet before taking it apart. Each faucet can be a bit different, so images of your particular once will be helpful. Post images of your faucet with your question. Use this guide for that. Here is a decent video about the repair as well.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Its a really good idea to shut the water off to the tap your going to take apart . you may have taps under the sink if not you'll have to shut the water off at the source where it comes into the house
из
@jimfixer totslly agree with you on that. That was one of the main reasons why I had this "cut the water supply to the faucet before taking it apart." in my answer....
из
Наиболее полезный ответ
A dripping faucet almost always must be disassembled in order to replace internal O-rings, seats, or washers. With some you replace the entire cartridge. There are many types and styles. The only way to know what you need is to shut off the water below the sink and then disassemble the faucet. This video shows how to do that with a traditional stem valve type: https://youtu.be/wPGFWtVhzYo you'll find YouTube videos showing how to deal with almost any type of faucet. Good luck!
Счет 2
Here are some steps you can follow to stop a dripping faucet:
  1. Identify the type of faucet: Different types of faucets have different mechanisms for controlling the flow of water. Knowing the type of faucet you have will help you determine the cause of the dripping and how to fix it.
  2. Check the washer: In most cases, a dripping faucet is caused by a worn washer. To fix the problem, you'll need to remove the handle and access the valve stem. Once you have the valve stem exposed, you can remove the washer and replace it with a new one.
  3. Check the O-ring: If the washer is not the problem, you may need to check the O-ring. The O-ring is a small, rubber ring that helps to seal the valve stem and prevent leaks. If the O-ring is damaged or worn, it may need to be replaced.
  4. Check the valve seat: If the washer and O-ring are not the problem, you may need to check the valve seat. The valve seat is a small, flat surface that the washer presses against to stop the flow of water. If the valve seat is damaged or worn, it may need to be resurfaced or replaced.
By following these steps, you should be able to stop a dripping faucet and fix the problem. If you're unsure about how to proceed, or if the problem persists after trying these steps, it may be worth seeking the help of a professional plumber.
Счет 1
Добавьте свой ответ
Nancy Wilder буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 11
За последние 7 дней: 31
За последние 30 дней: 156
За всё время: 23,362
