простой в использовании и легкий в очистке блендер серии 900 со сменными насадками, произведенный компанией Ninja. Выпускался в период с 2009 по 2013 год
My Blender is Leaking
Why is my blender leaking?
Это хороший вопрос?
Счет 1
4 Комментариев
When I'm ready to blend my contents, I set the lid on top and slowly turn it counter clockwise until I hear a click and can feel it is properly seated; then I screw it on very tightly. I hold it upside down over the sink and shake and it doesn't leak. I put it on the base, turn it on and, after about 10 seconds, liquid starts coming out. I turn it off and lift the container--the top is very loose. The blending action is unscrewing the top. This just starteda few weeks ago. The rubber seal is fine. Mine is the Ninja Professional 900 Watts.
из
I have this very model...Professional 900 and I'm experiencing the same problem. With detailed inspection of the screw on base / blade, I've noticed a very small crack in the plastic base, thus allowing small amounts of liquid to escape during operation. And recently I've noticed my blender smoking a tiny bit and smelling like an electrical fire when operating. I suspect the motor is compromised by the previous leaking at the screw on base. I would suggest that you carefully inspect your screw on base,...before you have motor trouble like I'm experiencing.
из
I found that after cleaning the gasket ring that the leaking was still happening. So I thought about the blades possibly being the problem. I ran my fingers along them and sure enough, after 2 years use, they were extremely dull. I sharpen them with a knife sharpener, which was a little difficult to get under the blades, and after it worked perfectly well without any leakage.
из
Recently i bought new 6 bladed blender from stylemaker.co.in some whare i missed 1 non leaked band at top of my blender i think so it's leaking how can i fix it
из
Добавить комментарий
2 Ответов
Выбранное решение
If your blender is leaking food or drink, either the rubber containment seal or your container is the problem. If the seal is dislodged or broken, head over to our troubleshooting to find a guide to replace it. If the container is your problem you will have to replace it. On the bottom of our device page is a link to the official Ninja product page. There you will find a link to order new parts.
iFixit Staff Suggestion: Check out our troubleshooting wiki for blender leaking from bottom.
Был ли этот ответ полезен?
Счет 3
6 Комментариев:
Good answer but no link to the guide you're referring to.
из
A fix - works - clean the seal in the lid. Even when washed after every use, if a little bit of whatever you were mixing gets in there, it builds over time. Take a flashlight and gently clean all around it that seal. I used a sharp paring knife but be sure not to cut the seal. As it is clear plastic, it is difficult to see. Now - there is no leaking. Sharpening the blades is also helpful.
из
I am on my second set of 2 blade/bases. They all have formed cracks radiating out from the blade bearing and they leak. It may be because I often blend frozen fruit. This still shouldn't happen. I see it as a bad design. If they made a metal replacement base, I'd be so happy.
из
I agree with Matthew Barncord ^. The power of the machine(torque during the PULSE function) is too strong for the plastic being used to form the Shark/Ninja blender carafe. This is my 4th unit - none has ever seen ice cubes. I purchased the blenders (Ninja Professional x2, and the Ninja Ultra Prep) to make breakfast smoothies with frozen wild blueberries. I've always PULSED first, as directed, and it makes little difference. Within 2 to 3 uses they all leaked. Back to the drawing board Team Shark/Ninja. You need a different material for the carafe. Stainless steel would be better suited to the advertised CRUSHING POWER
из
Regarding the ninja blender that leaks , can any of this leakage get into your drink?
из
Показать ещё 1 комментарий
The bottom usually screws off. Take it off, clean it, Check the gasket and screw it on tightly.
Счет 1
Добавьте свой ответ
Evy Pinero буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 15
За последние 30 дней: 72
За всё время: 31,872
