Смартфон Sony Xperia Z5 на базе Android был выпущен в октябре 2015 года. Sony Xperia Z5 оснащен 5,2-дюймовым дисплеем с разрешением 1080 x 1920 пикселей, процессором Qualcomm Snapdragon 810, 3 ГБ оперативной памяти и основной камерой на 23 Мп.
How to replace the frosted glass back?
I dropped my z5 dual straight on its back and the frosted back glass has shattered. If I buy the replacement part how would I go about replacing it?
Это хороший вопрос?
Счет 2
1 Комментарий
Here is the video showing how to replace broken z5 back cover:
https://www.youtube.com/watch?v=FY2z27SA...
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
You should check the model number first if this is a dual sim version?
You can check the model number of the Sony Xperia by using this:
You can buy the back cover from here: (It fits Sony Xperia Z5 E6603 E6653 E6633 E6683)
http://www.ebay.com.au/itm/Original-Glas...
Here's the guide on how to do it: Note that you only need to do step 1 and step 2.
Замена ЖК-экрана Sony Xperia Z5
Note: Please be careful because if I'm correct there may be a white NFC sticker tag on the back cover (It is a white sticker with two golden contact points). This model probably doesn't have it. If it does, you'll need to heat it up then carefully separate it from the back cover as it is held by adhesive.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
No backlight in Sony xperia z3 compact. Solución please
из
I did all those steps now nfc doesn't work. Maybe sticker not making contact with the motherboard. Do I need to buy a new sticker? And if I open the back cover again, will it remove all the glue, needing a new cover?
Счет 0
Добавьте свой ответ
Karthik Krishnan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 12
За всё время: 20,711
