Why does my coffee taste bad?
My coffee usually tastes good. Recently though, my coffee has tasted worse and the coffee grounds are kind of gritty in the coffee. What should I do to correct this?
Это хороший вопрос?
Это хороший вопрос?
If your coffee is tasting bad, it could be a result of poor water quality, incorrect coffee to water ratio, the coffee grounds are either too fine or too coarse, or the coffee maker might be dirty. Solutions to these issues can be found in the Hamilton Beach 48464 Troubleshooting page.
Был ли этот ответ полезен?
There are some another serious reason for your coffee is tasted bad. If you don’t clean your coffee machine regularly then your machine make a bad effect to your coffee flavor. The coffee flavor with smell and drinking bad. So you must need to clean your machine every 2 days of 3 days.
Or if your coffee bean is grinned with high speed then it can create a bad flavor taste.
You can let straight vinegar sit in the tank overnight. Believe it or not, it might fix a whole lot of taste issues.
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 10
За все время: 1,887
1 Комментарий
Have you changed anything? Where do you get your water?
из mayer
