perserving heel and soul using silicone
New boots showing wear after being worn 4 times. Would a coat of silicone protect against wear?
Это хороший вопрос?
Это хороший вопрос?
You may be able to use silicone to rebuild your worn outsole, though the success of this repair might depend on the product you are intending to use and the type of material your outsole is made out of (leather, rubber, etc.).
A tried-and-true product specifically used for shoe repair is Shoe Goo. Here are two guides to help you complete the repair:
Hope this helps!
Инструкция
Сложность:
Модерировать
30 minutes
Инструкция
Сложность:
Очень просто
15 minutes
Был ли этот ответ полезен?
If these are leather you can use several things:
These are made of hard plastic:
http://www.amazon.com/Traveler-Plates-Na...
These are nylon:
http://www.ebay.com/itm/10-pr-Guard-Heel...
These are metal:
http://www.ebay.com/itm/DIY-metal-BIKER-...
These are hob nails, worked well for the German army:
Here's something you might try. A bit costly I admit, but your shoes will wear down the pavement instead of the other way round ;)
(sorry, couldn't resist)
You dont want to walk on any glass floors with those shoes
我不知道!我不知道!我不知道!我不知道!我不知道!我不知道00!
At least you know you dont know
За последние 24часов: 1
За последние 7 дней: 13
За последние 30 дней: 59
За всё время: 3,929
1 Комментарий
I sprayed silicone on the boot material
из michelle.jarvid
