Machine will not turn on
went dead and will not turn on. power supply is good and switch is good. Can not find a mother board for it.
Это хороший вопрос?
Это хороший вопрос?
Try this disconnect the power cord and hold down the power button for 60 seconds then plug it back in and see what you get
Был ли этот ответ полезен?
Hello CARL C VANPELT
I only got one solution for this connect the plug to another one at your home to see if the connector is getting power if that didnt work open your desktop and unplug everything wait 60 seconds and plug everything back on to see if your getting any power double check to see if there is no plug missing or damage if that doesnt work you can open your power supply and see if you can find any capacitators damage or other components (WARNING) do not open it if you are inexperience
Hope this help solve your problem :D
you wont gain experience unless you boldly go were so many have gone before you
Its on but the green power bar is very light
Hey, from your post it sounds like your looking for a motherboard and cannot find one, sounds like u have tested the PSU, and I'm not certain what switch is good, but if u can provide me with the motherboard number I'm sure either I or someone here can find u a mobo for this PC, alternative, I'm not certain that this PC is actually worth getting another mobo for it
http://m.ebay.com/itm/eMachine-ET1831-2G...
Here is a similar PC and is going for 110$, this might be the route you take
http://m.ebay.com/itm/MCP73VT-PM-eMachin...
Here is a mobo I think it might be the right one but I cannot confirm without the mobo number, but see the price for a full one of these is going for around the same price as the mobo itself, but let us know if u need anything else
Try replacing the motherboard battery. The watch battery looking thing. I did, works great.
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 22
За все время: 13,823
3 Комментариев
have you tried a the power supply in another machine or are you thinking its fine because it powers on and you hear it?
из Jimfixer Поделиться
When i connect my monitor to my computer it pops up and turns black like it turned off.
из Acid Boy Поделиться
Replace the Hard Drive. Then it will work
из CARL C Поделиться
