Экономичная версия смартфона Samsung Galaxy S4, выпущенная в июле 2013 года.
Phone not starting anymore
My Samsung S4 mini doesn't start anymore. I put it on charge last night, and it was dead this morning. Holding down multiple buttons doesn't give me any repsond, not even vibrating. But when I plug it into my computer i can see a RELINK HS-USB QDLoader 9008 (COM6). If I can't fix the phone, I would at least like to try to save the data. Also, are there any other phones which use the same battery? That would make it easier to get hold of a battery to test if that's the problem.
Это хороший вопрос?
Счет 4
1 Комментарий
my mobile is moto x xt1056
and in my mobile is no memory card option plz help
qualcomm hs-usb qdloader 9008 (COM5)
zainmarain@gmail.com
из
Добавить комментарий
7 Ответов
Наиболее полезный ответ
Hey bla, try this:
  1. Uninstall drivers from device manager and enable test mode in your computer.
  2. Follow this video: https://www.youtube.com/v/R4SVSovw4Jo
- The guide is for a different phone but it should unbrick your device.
- Let me know how it goes.
Был ли этот ответ полезен?
Счет 3
3 Комментариев:
What is "test mode"?
Also, the guide you gave completely overwrites the system, is there any other solution to read out the current memory first?
из
-Google "how to enable test mode" for your version of Windows.
-Your phone is bricked. Usually when this happens, the partition on your device is corrupted and overwriting the system is the only way to fix this. Normally, recovering data from a bricked phone is almost impossible.
из
Test mode allows you to install or use unsigned, unverified device drivers that microsoft have not tested and certified for windows. Basically unofficial device drivers in come cases.
из
I have the same problem on my Samsung S5 what I need to do ? Relink HS-USB QDLoader 9008 (COM6) heelp
Счет 0
I have hard bricked samsung galaxy s4 mini i9195 - I tried this method with QFIL software Qualcomm HS-USB QDLoader 9008, unbrick-qualcomm-mobiles does not work for me (( then found sdcard trick with debrick.img file -- for several times, my phone goes in download mode - I flashing stock rom / 1 file firmware, then with pit. 4 file firmware--not work - i got bootloop HARD BRICK
Счет 0
Hi elarci, can you send me the link for the debrik.img you used ?
i am not able to get my phone in dowload mode , i've tried also the way by SDCARD but my phone wont boot at all
it is only recognized as QDLoader 9008
thanks
Счет 0
how i am fixed this problem
Счет 0
if that happen your Bootloader is corrupted. You have to bring your Phone to Repair Shop he can use JTAG Box or ATF Box to debrick your Phone.
Счет 0
HI, have you tried QPST? If your phone is detected as qdhsbloader 9008 then you can try it. Also download a fresh Rom for your device. Hope this helps. -chris
Счет 0
Добавьте свой ответ
bla буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 8
За последние 30 дней: 34
За всё время: 21,395
