Беспроводная клавиатура Apple четвертого поколения. Выпущена в октябре 2015 года. Модель A1644.
numbers not work at magic keyboard
hi all
the numbers 1-9 not work at my magic keyboard, zero is working
batary is full
wifi is on
any help plz
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
Double check that the Magic Keyboard is not paired to anything else other than the device / computer you are using. Having it paired to multiple devices causes this issue.
Source: https://discussions.apple.com/thread/390...
Posted by user 'softwater':
Yes, just had this issue, but you'll need another keyboard to solve it (buy the cheapest bog-standard usb plug in one you can find from any computer store if necessary).
1. Ensure the batteries are freshly charged and insert. Turn the device on with a single, brief push of the button.
2. Observe the green light. It should stay on for about 5 seconds, and then start blinking. If it's not blinking, remove the batteries and recharge them till the green light on the charge is on.
3. If you have any other bluetooth devices (iPad, iPhone, etc), go into their bluetooth settings and remove the keyboard from their list of devices if it's listed.
4. On your mac, from the bluetooth icon in the menu bar, choose 'Open Bluetooth Preferences...'. If the keyboard is listed there, control click on its name in the window pane and choose 'Remove'.
5. Wait while the bluetooth manager searches for your keyboard again. When it comes up with a pairing password, type what it says on the bluetooth keyboard and press 'return'.
Hopefully, you'll see the status change to 'Connected'.
Был ли этот ответ полезен?
Счет 1
6 Комментариев:
if the numbers 1-9 do not work, I won't be able to type the pairing numbers. So this is NOT a solution to go for.
из
I have the same issue, any solution ?
из
Has this issue been resolved, i am looking to hard reset to factory default without computer just a combination of keys. Any ideas?
из
I have the same issue any update on the issue
из
Same issue. Any help????
из
Показать ещё 1 комментарий
Добавьте свой ответ
fadel буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 27
За всё время: 11,820
