Это 8,0-мегапиксельная цифровая камера с защитой от воды и ударов. Она также оснащена такими функциями, как 3-кратный оптический зум и распознавание лиц.
LCD screen is black
my cameras lcd screen is black i cant see anything it still takes photos tho but i cant see them?
Это хороший вопрос?
Счет 2
1 Комментарий:
I am having this problem as well. Did you ever find an answer? Stylus 850 SW camera, screen is black, lens is open, I take a photo and plug camera in to computer and there’s a file there but its just a black rectangle
из
Добавить комментарий
1 ответ
Hi @mormongirl782
Can you view the menu settings in the camera’s LCD screen?
If so then the LCD screen is OK and since you can “take” pictures and download them, this proves to a degree that the motherboard is working OK also.
The problem appears to be with the camera’s CCD image sensor or its’ connection to the motherboard.
I cannot find a replacement CCD sensor online or even a teardown of the camera to see how to open it to gain access to the sensor etc to check if anything was loose.
Given the cost - examples only of the camera, it would be doubtful that if the problem was a faulty sensor and not just a connection problem, that you could source a replacement sensor any cheaper than replacing the camera itself.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Hi Jayeff!
I can view the menu settings in the camera's LCD screen, yes.
When I take photos and download them/hook the camera in to view on the computer, it's just a black rectangle :(
из
Добавьте свой ответ
tamarah cooley буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 11
За последние 30 дней: 45
За все время: 1,585
