Pentium M 1,6 ГГц, 512 МБ ОЗУ, жесткий диск 40 ГБ
SSD Hard Drive Kit
I have an old IBM ThinkPad T41 with a missing hard drive. I have an SSD drive, but I don't have anything to hold it in place in the hard drive slot. What items would I need to purchase ?
Это хороший вопрос?
Счет 0
1 Комментарий
I don't know how crazy you want to get, but some good carpet tape will hold it :)
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
Hi,
You could purchase a laptop HDD caddy.
Most SSDs should fit into the caddy with the screwholes lining up.
Here is a link that shows how to remove the HDD from a T41 laptop. Just reverse the procedure.
http://www.laptopinventory.com/LaptopInv...
Here is a link, from just one supplier, that shows what a caddy costs and looks like. There are a lot more suppliers if this one doesn't appeal to you. Just search online for Thinkpad T41 HDD caddy.
http://www.tmart.com/Hard-Drive-Cover-Ca...
You may have to pack out the SSD a bit if it is thinner, to support it (even with the screwholes lining up) , so as to not place too much stress on the connectors. Any foam or rubber type material should be suitable.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Brian буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 23
За все время: 1,237
