G71t-300 — это ноутбук, выпущенный HP в августе 2009 года. Это универсальное потребительское устройство, оснащенное встроенной веб-камерой, видеокартой и операционной системой Windows 7.
How to fix Wifi problems?
My HP G71t-300 does not detect my home Wifi. I have tried turning the device on and off already, as well as resetting my router.
Это хороший вопрос?
Счет 2
Добавить комментарий
5 Ответов
Наиболее полезный ответ
Maybe your wireless drivers are out of date. You might consider plugging into ethernet temporarily and updating those drivers to see if it resolves the issue.
Был ли этот ответ полезен?
Счет 1
Check if you can connect to your home network with a 2nd laptop. If you can, then the 1st laptop has something wrong with either the wifi module itself, or the drivers for the wifi module is not installed/the wrong one. For replacing the module, see this guide. For installing the drivers, download them from the HP website using another computer, and transfer it to the 1st laptop via an external storage device.
Счет 1
If your laptop can detect other Wifi signals but not yours, then this is most likely an issue with your internet provider or modem and not with your laptop.
If none can be detected, however, you may need to replace the Wifi card in the device. Refer to this pagefor further information.
Счет 0
If your laptop detects other networks, then it may be an issue with your internet provider or your router/modem. Contact your ISP for further assistance.
If no networks can be detected, you may need to replace your wifi module.
Счет 0
If your laptop doesn't detect any wifi networks, the laptop's wifi connectivity may have been disabled. Check that the switch for the wifi card is on or find the key to turn on wifi.
Счет 0
Добавьте свой ответ
Jake Dykeman буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 17
За все время: 526
